Old 08-06-18, 04:15 AM   #1
Chaplain
Junior Member
Default SV Frankenstein trackbike build. (Pic heavy)
Decided to retire my Aprilia Mille R from a track bike to a street bike. As a track replacement I purchased a '05 SV650s. Previous owner had the SV setup for super stock club racing and he out weighed me by a good 60lbs. I knew I would have some work to do in order to get bike properly setup for me as well as a number of other items needing addressed to "make it mine."
At first I was just going to clean it up, put it on a much needed diet, prep, change spring rates and valving and run it. One thing let to another and now I have a fullbuild on my hands. Half ZX6R half SV650, some Yamaha bits as well as Ape bits with every thing (outside of new Michelin Tires) being bought used off a couple different forums, eBay and of course local ads.
Why a ZX6R and not a traditional GSXR swap you ask? Well I don't have a smart answer for you other than; 1) I like the design of the Kawasaki swingarm better, 2) their wheels are lighter and better looking imho and 3) I just wanted to do something different than the traditional swaps.
Im open to constructive comments and even criticism if it comes with a reason. Here are some pics to keep the thread interesting:
Swingarm needed to be notched to clear shock.
Battery and rectifier relocated and bike rewired as track bike.
A handful of parts were taken to Full Throttle Powdercoating in Corona .CA. All bearings were replaced afterwards.
Front forks are freshly rebuilt with Ohlins 25 carts inside and a Scotts damper up top. Top/bottom yokes shaved.
How "SV Frankinstine" sits now, just need to build exhaust and tie up some loose ends. At the end of the day I made something different, put my twist on it, and I sure hope it works!
Suggestions? Thoughts?
FYI: I have a bin of leftover and mockup parts for sale from '05 SV, '03 GSXR, and 05-08 ZX6R.
#3N1Motorsports
#FrankensteinSV650
Chaplain is offline   Reply With Quote
Old 08-06-18, 06:21 AM   #2
Default Re: SV Frankenstein trackbike build. (Pic heavy)
Looks blooming great so far
Old 08-06-18, 06:36 AM   #3
Geodude
Geodude's Avatar
Agreed
Old 08-06-18, 08:03 AM   #4
Craig380
Looks great, and very purposeful! I reckon it would look even meaner if the swingarm was satin black to match the frame, but that's just me
Does the bike have any major engine mods apart from the exhaust? That M4 system looks cool.
Old 08-06-18, 09:57 AM   #5
Not sure about the ironing board but the rest looks awesome!
Old 08-06-18, 12:34 PM   #6
looks good and a job well done so far.
Old 08-06-18, 01:35 PM   #7
Chaplain
Junior Member
No motor mods, trying to keep it as reliable as possible but we'll see.
Swingarm was black but needed to be stripped to weld on. Also, I wanted a very raw looking bike and was originally going to have the frame stripped as well. If you look close at the fuel tank you'll see that it's clear powdercoat not gray. You are right, it would flow together better for the eye if the swingarm was black.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Old 08-06-18, 01:45 PM   #8
Chaplain
Junior Member
Thats funny. The "ironing board" actuallly serves a purpose. I relocated the electronics, namely the rectifier' under the seat away from the motor heat. The "ironing board" is there to capture air and has vents to allow air to escape. Not sure about SV's, 1st one, but my Aprilia produces a lot of heat which kills its electronics/charging/starting issues. You know I'm going to call it the ironing board now
Here's some undertail pics:
Here it is in stock form, I cut pounds of weight off this tail.
Old 08-06-18, 03:52 PM   #9
Craig380
I really like the clear powdercoat on the tank, it's a great (non) colour!
Old 21-02-19, 05:37 AM   #10
Chaplain
Junior Member
Thank you. It really looks great in the sun, has a real 3D effect.
Sent from my SM-G960U using Tapatalk
My Externally "customed" frankenstein of an SV650 CLARKYsv SV Talk, Tuning & Tweaking 17 24-06-15 04:49 PM
Trackbike build threads?? dw22 Bikes - Talk & Issues 2 08-03-15 11:54 PM
botched frankenstein???? leebex Photos 51 04-07-11 07:58 PM
Frankenstein's front end changes again northwind SV Talk, Tuning & Tweaking 22 16-10-07 10:51 PM
Lady Frankenstein Lives (Nearly There!) Jester666 Photos 24 25-05-07 11:43 PM
