Old 19-06-18, 02:31 PM   #1
drbyers
Junior Member
Default Braking performance
Is it just me or is braking performance on the older generation SVs mediocre? I've had 600s, 675s and liter bikes and they've all had significantly better braking performance. I mean, it's not even close. My current 2006 has abysmal stopping power.
I've sanded down the pads and rotors and bled the brakes. The only thing I haven't done is a brake pad upgrade. It's just unnerving how long it takes to come to a complete stop.
drbyers is offline   Reply With Quote
Old 19-06-18, 02:42 PM   #2
shiftin_gear98
shiftin_gear98's Avatar
Default Re: Braking performance
I managed to stop on my K6 from about 85 to a stand still in about 4 car lengths when an Audi driver changed his mind and the room ran out really quick. No idea how I managed to warp the laws of physics but I'm really glad I did. I don't think the Audi driver quite believed it either.
Nothing wrong with SV brakes - and mine could really do with a service.
Old 19-06-18, 03:04 PM   #3
with all two pot sliding callipers they need serviced properly and regularly to get the best out of them.
when i say serviced i mean a proper strip down to individual components and seal grooves cleaned out then assembled with RRG. same goes for the mater cylinders.
the best pads i have used are DP Brakes (Dunlop Pads), their bite, feel and wet weather stopping is superb. EBC by comparison feel wooden.
v-twins dont need massive stopping power as they have lots of engine braking and most long term riders of them tend not to use the brakes much and instead rely on the engine braking. i have a gsxr front end and radial brakes on my SV and its a lethal combination with the engine braking, its too good.
Old 19-06-18, 03:11 PM   #4
Craig380
Brakes on my K6 are fine, I can get the back wheel off the ground with two fingers. It's two years since I bled them and greased the slide pins, although I don't ride when it's wet so they see minimal water/salt spray
Old 19-06-18, 03:33 PM   #5
Talking Heads
Braking performance is limited by grip betwixt tyre and road rather than hardware.
SV brakes just require a harder pull.
Talking Heads is offline   Reply With Quote
Old 19-06-18, 03:36 PM   #6
johnnyrod
johnnyrod's Avatar
My bike has about 45k on it now and the brakes definitely aren't as good as they used to be, even after a good going over. I've not looked at the sliding pins for wear, but a good few years ago you could haul it up a lot quicker. I'm referring to track riding, where you get plenty of opportunity to heave on the brakes hard and repeatedly, as well as road riding where like Bibs says, you don't need them that much once you're out of town.
Old 19-06-18, 03:40 PM   #7
brakes cant be that bad as the supertwin racers have to use them and they go pretty fekin quick.
Old 19-06-18, 05:40 PM   #8
Well Berlin used to haul up a minitwin plus 20st exceptionally well with standard brakes and race pads
Sent from my PRA-LX1 using Tapatalk
Old 22-06-18, 05:14 AM   #9
johnnyrod
johnnyrod's Avatar
My experience is clearly no match for your anecdote. Perhaps mileage and an £80 set of brake pads are in there somewhere.
Old 22-06-18, 05:33 AM   #10
Was using it as an example. Tbh that bike could have had a 100k on it as the speedo failed at 60k
Trail braking. Blue_SV650S Bikes - Talk & Issues 33 16-10-08 12:30 PM
An odd braking problem (car) ooger Idle Banter 16 30-07-08 04:57 PM
Braking SV650S '99 r4ce_e3nd For Sale - SV's and SV related items 17 16-11-07 01:11 PM
knocking when braking Grinch SV Talk, Tuning & Tweaking 2 06-02-07 09:15 AM
engine braking on the sv! kwak zzr SV Talk, Tuning & Tweaking 11 25-04-06 12:01 PM
