Old 12-07-18, 12:15 PM   #1
quimjuicemonkey
Default regulator
hi just quick question on the regulator there are 3 yellow to yellow wires is there any pattern to them thinking not as all yellow ???????
quimjuicemonkey is offline   Reply With Quote
Old 12-07-18, 12:39 PM   #2
Default Re: regulator
in reality no but always best to replace like for like.
search google for how a motorcycle stator works to get a better idea and decide for yourself.
Old 12-07-18, 01:43 PM   #3
Curvy had two types of RR one with two connectors one with a single plug
But both have 3 yellow wires if I remember.
Do a search of Electrex one using sv650 try again using sv650s, then you'll see both types
Old 12-07-18, 07:44 PM   #4
R1ffR4ff
R1ffR4ff's Avatar
The 3 high current wires from the Stator are not polarized e.g they can be connected anyway round but as Bib says stick to the original setup and you can't go wrong.
The two DC wires from the R/R ARE polarized e.g they have a positive and negative(Ground) and MUST be connected correctly.
Have a read here,
http://puttingoutfires.x10host.com/M...sfetUniRR.html
The rules are the same.
HTH
Old 12-07-18, 09:17 PM   #5
fizzwheel
fizzwheel's Avatar
It'd be handy if you stated what bike this was from / for...
Old 17-07-18, 10:06 AM   #6
quimjuicemonkey
sv 650s 2000 bought one from ebay plugs seem wrong way round red to red black to black fine but it the 3 yellow to yellows wired up all seems ok now
Old 17-07-18, 10:09 AM   #7
R1ffR4ff
R1ffR4ff's Avatar
When you say fine do you mean it's fitted and working.I would just check the polarity of the Regulator wires.
The negative pin on the Regulator should go to ground.
regulator/rectifier Daywalker Ancillaries 0 01-05-16 08:40 AM
Curvy regulator Dickyholdsworth Stuff Wanted 1 23-03-10 04:56 PM
Regulator wilky007 Stuff Wanted 1 08-06-09 05:03 PM
Where is the regulator philbert SV Talk, Tuning & Tweaking 7 26-09-08 05:21 PM
It must be the regulator... NadineDieBiene SV Talk, Tuning & Tweaking 7 05-11-07 01:06 PM
