Old 27-12-18, 05:14 PM   #1
mister c
mister c's Avatar
Default 1979 Suzuki X5 Long term rebuild
Hi.
I seemed to have put my rebuild in the wrong part of the forum. If you would like to see how this started, the thread is here https://forums.sv650.org/showthread.php?t=231180
So, with Christmas upon us, progress has been slow. New tyres were fitted & not a lot else has happened. I've ordered some new parts & even found a couple of impossible to find bits in Indonesia of all places .
The 1st impossible piece is the handlebar cover. This is a small piece of plastic with "Suzuki" embossed on it. Sat on Ebay at stupid o'clock in the morning & came across this part after hours of trawling.
The Suzuki part isn't painted on the X5, so I took some very fine wire wool & sanded it all off. I then had to make a bracket out of some aluminium plate I have in the shed & fitted it. I'm really pleased as it looks OE.
I also noticed that when the tyres were fitted, the shocks looked wrong. I was correct, when I measured them, they were 280mm centre to centre, X5 shocks are 300mm. I found a compnay called TEC, their shocks look just like standard & were a great price too. They arrived within a couple of days & were really easy to fit. They have made one heck of a difference.
I've also found a brand new old stock chain cover from the same place in Indonesia & a brand new tail piece cover from a seller in the UK, but waiting for these to arrive.
Today I had some indicators & the front mudguard arrive, so, after work set to in the shed to fit them. The indicators were nice & easy to fit, but the pattern mudguard was a different story. I've had to drill the mounting holes, so used the original as a template. When I drilled the holes & mounted it. Unfortunately, it's sitting a little high, so, tomorrow after work, I'll do some jigging & filing to get it sitting right.
Hopefully I should have a few more parts turning up over the next few days.
Old 27-12-18, 06:01 PM   #2
garynortheast
garynortheast's Avatar
Default Re: 1979 Suzuki X5 Long term rebuild
This is really coming together nicely now Col. It looks so close to being there.
Blue Curvy S with over 111,000 miles and still going strong.
Old 27-12-18, 08:33 PM   #3
Craig380
It's looking great! I have a memory that the plastic handlebar trim on my old X5 had the lettering picked out in silver, but that may not be correct.
Old 27-12-18, 08:34 PM   #4
A labour of love there Col, especially sourcing those difficult parts
Old 27-12-18, 09:38 PM   #5
Sir Trev
Sir Trev's Avatar
Col - you're quite the magician my friend. Wish I had the patience to do something like this.
Old 28-12-18, 05:07 AM   #6
mister c
mister c's Avatar
Still a fair way to go yet Gary. I'm thinking of removing the engine again as the middle crank bearing is a little noisy, I can't make my mind up as I won't be riding it that often
I'll be honest I can't remember on my original one, but all of the pictures I've seen, they are black
I think that sourcing parts is one of the fun parts of the build, it takes a while, but you feel quite accomplished when you find them
It takes my mind away from reality Trev, plus, I should have a nice bike when it's all done
Old 28-12-18, 11:43 AM   #7
looking superb
Old 28-12-18, 05:08 PM   #8
mister c
mister c's Avatar
Came home from work today & found that another couple of items had dropped through the letterbox. The correct kickstart & a pair of fork reflectors, so, after going food shopping with the missus, I headed off into my leaky shed to play.
The kickstart was plug & play, so a quick tap with a mallet & tighten a screw, it's on
Next on the agenda was lowering the front mudguard. It didn't take me too long to re drill 4 holes a little further down the ribs & check to see what it looked like. In my opinion, a lot better. It could go lower still, but I think it looks right now. I took the grinder to the excess webbing & ground it to tidy it up.
The last part today were the fork reflectors. I ordered 2 from China for £2.20 delivered. When I opened the packaging, there were 2 PAIRS in the bag. So I had 4 reflectors for £2.20 delivered from China, how on earth is that possible?
I did have a slight problem as the screws on the reflectors were 6mm & the holes in the yoke are 5mm. I took a reflector apart to see how they were made & it had a screw bonded into the plastic. I used my grinder to get rid of the excess plastic, removed the screw & replaced it with a 5mm one. I screwed it into the yoke & replaced the reflector top. It's as good as new
Old 28-12-18, 07:10 PM   #9
garynortheast
I assume the hole in the mudguard is for a speedo cable guide/fixing?
Old 29-12-18, 08:25 AM   #10
mister c
mister c's Avatar
It is mate, yes
Suzuki X5 long term project mister c Photos 46 10-03-19 07:47 AM
Hello All! - From a long-term lurker CH3N5O South & West Surfers 9 18-02-14 12:44 PM
long term unemployed to get vouchers. leebex Idle Banter 81 25-12-12 08:46 AM
Do you have long term goals? Fallout Idle Banter 52 17-08-12 04:56 PM
another build thread (long term) barwel1992 Photos 24 03-06-11 11:13 PM
