29-05-20, 04:54 PM | #1 |
Any idea??
29-05-20, 05:25 PM | #2 |
Re: Any idea??
Water got in Mines done it before.
29-05-20, 06:42 PM | #3 |
Re: Any idea??
If not water, could be bad earth ( sorry 'negative common' )
29-05-20, 07:07 PM | #4 |
Re: Any idea??
its the supernatural thigmay bobbs.
29-05-20, 07:25 PM | #5 | |
Junior Member
Re: Any idea??
Sent from my SM-G975F using Tapatalk |
29-05-20, 07:40 PM | #6 |
Re: Any idea??
May be water in the hazard flasher switch, which would bring both indicator lights on dim, and then when you turn left and right is it just the dash indicator for that side that flashes bright ? We have had no rain up here for a couple of months now, have you had rain or have you washed the bike ?
29-05-20, 08:07 PM | #7 |
Re: Any idea??
Have you got LED indicators fitted? They cause that issue
29-05-20, 08:12 PM | #8 | ||
Re: Any idea??
Ahh right i havent washed the bike recently and havent been out in rain but will it go if it dries out?
Where would that be? Quote:
Yes i have led indicators fitted, ive got a led relay for it thought |
29-05-20, 08:25 PM | #9 |
Junior Member
Re: Any idea??
Then your cables are touching something they shouldn't you need to get it checked out
29-05-20, 08:27 PM | #10 |
Re: Any idea??
I checked all the indicator wiring and all that seems fine, what other wiring should i check
Telefonica SV - good idea/bad idea? Poll | Paul the 6th | Bikes - Talk & Issues | 25 | 31-01-08 09:27 AM |
Just an idea... | Davido | Idle Banter | 33 | 01-02-07 02:11 PM |
Just an idea........... | zedleppelin1981 | SV Talk, Tuning & Tweaking | 18 | 11-01-07 05:08 PM |
good idea or bad idea ? | hall13uk | Idle Banter | 45 | 17-12-05 03:29 PM |
