Old 01-12-20, 01:53 PM   #1
gt alex
Default Building a intake with a single mechanical TB from the 60's
I am a bit crazy but I believe this is worth a try, on my 02 sv650 Cafe Racer
It is called a fish Carburettor Designed circa 1930 but in truth it is a mechanical map sensor that dispenses fuel and air (dual fuel) thru a throttle shaft that doubles as a spray bar, and as such is also altitude compensation.
http://forums.sv650.org/attachment.p...1&d=1606830653
gt alex is offline   Reply With Quote
Old 01-12-20, 02:13 PM   #2
admin
John T
admin's Avatar
Default Re: Building a intake with a single mechanical TB from the 60's
Interesting. I'll be interested to know how the bike runs with that.
Old 01-12-20, 03:46 PM   #3
SV650rules
Anyone remember the Wal Phillips fuel injector ?
http://victorylibrary.com/brit/WP-c.htm
http://victorylibrary.com/graphics/WP9f_1_b.JPG
2016 SV650 AL7
Old 01-12-20, 03:56 PM   #4
Seeker
Seeker's Avatar
Originally Posted by SV650rules View Post
Oh yes, my friend and I spent many hours trying to get one to work. It never did.
2016 SV650AL7
2023 GSX-8S
Old 01-12-20, 05:33 PM   #5
svenrico
svenrico's Avatar
Glad mine came with fuel injection as standard !
svenrico is offline   Reply With Quote
Old 02-12-20, 08:02 PM   #6
gadget
Not crazy at all, they were originally called 'Reece Fish' carbs, I used them on my Maguire Mini back in the 80's.
Very easy to calibrate and very reliable once tuned to your particular application.
Will be interested to hear how you get on with it.
gadget is offline   Reply With Quote
Old 04-12-20, 10:43 AM   #7
gt alex
You are on the right path the Reece fish was a unofficial copy for European applications the official euro model was the minnow fish.
The reece fish had the nice feature of pivoting metering assembly so it could be side draft,semi own draft or down draft.
The minnow fish was only down draft (to my knowledge) due to the bell mouth shape.
The one I am using is much older and made for American car application
An update
I notched out the metering pickup,(to reduce the minimum fuel flow rate) but due to tight tolerances not much was gained.
I may have to live with a hi idle but the exhaust noise is way louder.(too loud a real surprise)
I will do some more fine adjustments and test rides tomorrow. but dyno tuning still won't happen till mid January)
Old 04-12-20, 05:58 PM   #8
gadget
Sounds really interesting, the reece fish setup i had on my maguire were a bit of a frankenstein affair tbh, I didn't know much about them at the time as they were already fitted when I bought the car for Hill climb. I had them set up by a local guru and they performed faultlessly from there on. He told me they were ideally suited to the Arden 8 port head i was using so never felt the need to change them for Webbers or the like.
Old 13-12-20, 11:58 AM   #9
gt alex
Ok. Time for an update,
If idle speed is correct too much fuel is being delivered thru out the whole range. If I adjust for a 3500 rpm Idle I can get it all good.
So I am going to try a 2nd spray bar I have for the 100 hp version which has smaller holes I am not sure of compatibility with this larger TB but it's the best bet at this time.
Old 14-12-20, 12:49 PM   #10
SV650rules
IMHO If these proprietary items were any good they would have replaced carbs, they must be a lot cheaper to produce. There is a lot of technology in carbs that had been developed over a long time for their purpose..
2016 SV650 AL7
mechanical help? 2hys SELKENT 5 15-11-09 11:05 AM
Mechanical Help Please! Noble Ox SV Talk, Tuning & Tweaking 59 08-11-09 03:15 PM
Car mechanical questions the_lone_wolf Idle Banter 17 20-03-08 04:52 PM
Mechanical Aptitude Dicky Ticker SV Talk, Tuning & Tweaking 2 15-04-07 07:48 AM
Mechanical Advice..... SoulKiss Bikes - Talk & Issues 4 07-12-06 09:59 PM
