Hey all, can anyone tell me if the rear shock rom a 03-06 sv650s will fit a 99 curvy without any mods or chopping about? What are the advantages (if any) of using this shock over the standard curvy shock? Only asking as I have the chance to buy a NOS 04 shock complete in its packing for peanuts, it appears to have some kind of valve on a reservoir ... is that an air valve? If so.. I assume it's adjustable?
It also has a small (flat blade) adjuster too, would that be for damping or rebound or ???. |
I know the standard shocks of 1st and 2nd generation are different in length by 10mm but what your describing isnt a standard item certainly for UK models. The shocks that are fitted to both versions here dont have a reservoir or adjustable damping so it sounds like maybe thats one for a GSXR in which case the battery box will need modifying...
#3 | |
I think I'll pass on it tbh, I certainly don't want something that's an unknown and will most likely cause a major headache. |
Pity as the original shock is a low budget item so nice to upgrade but the space for the reservoir, unless its remote one, is pretty limited...
Indeed, would have been a good upgrade if the reservoir was remote but it's fixed and tbh I'd rather not do any hacking about. As my original shock seems to be behaving atm I'll leave well alone until I decide which upgrade to go for, probably a Penske or Ohlins when funds permit.
I have a Penske triple clicker from a ZX6r but it works with both gens 1&2 on the SV due to right height adjustability. HMU when you want to upgrade.
954 Fireblade Rear Shock Swap? | JamesMio | Bikes - Talk & Issues | 7 | 27-08-11 05:31 PM |
Std Curvy rear shock. Swap WHY | Berlin | For Sale - SV's and SV related items | 6 | 19-07-10 07:26 PM |
Rear Shock Swap- What Else Fits a K2? | Binky | SV Talk, Tuning & Tweaking | 1 | 27-06-09 04:23 PM |
K8 SV650S rear shock swap | MichaelMickSV | SV Talk, Tuning & Tweaking | 14 | 12-06-09 11:32 AM |
ZX6RR Rear Shock swap | Couerdelion | SV Talk, Tuning & Tweaking | 1 | 21-02-05 05:07 PM |
