Old 03-06-21, 08:01 PM   #1
gadget
Default Clutch cable mod.
Hi all, I've seen/ read few posts on clutch cable replacement when changing 'S' clipons to full handlebars, I have ordered some 30mm risers to fit to my 'S' to yoke and I have some bars from an FZ1 which seem pretty much spot on for comfort/ riding position. I will more than likely have to change the clutch cable to a longer item, my question is ... which one do I go for that would be a direct replacement? Naked bandit? Suzuki DL? Standard SV? if anyone can recommend any of these... which model/ year would be best?
Cheers.
gadget is offline   Reply With Quote
Old 04-06-21, 09:30 AM   #2
Default Re: Clutch cable mod.
you could always ask Venhill to make you one the length you want.
Old 04-06-21, 10:00 AM   #3
gadget
Thanks for the suggestion, I did contemplate having it made up but just wanted to know if anyone here had done the conversion and has used an 'off the shelf' cable that fits with no hassle or modification. I suppose it will be difficult to say which cable fits exactly due to no two conversions being the same but if for example a DL fitted with no problems or mods with a similar bar setup I would probably go for that cable.
Old 04-06-21, 01:02 PM   #4
Jayneflakes
Jayneflakes's Avatar
I used the cable from a V-Strom when I did my bar swap.
Jayne you're a Pussy Magnet
Old 04-06-21, 03:12 PM   #5
IIR the bandit 650 K5 is the one i use on the pointy (K7) with a full comfort kit and Renthal high Superbike bars.
Old 04-06-21, 07:20 PM   #6
gadget
Any particular year cable? 650?
Old 04-06-21, 07:22 PM   #7
gadget
I have a curvy, does it make any difference between curvy and pointy to me using a bandit k7 650?
Old 11-06-21, 12:06 PM   #8
Biker Biggles
Biker Biggles's Avatar
Would a curvy naked cable be suitable?
Old 21-06-21, 06:25 PM   #9
Blapper
Blapper's Avatar
I had venhill make mine still got a fabulous light clutch.
Super heavy clutch pull (Snapped clutch cable) Barney626 SV Talk, Tuning & Tweaking 21 21-02-20 02:00 PM
New clutch cable, adjusted and still not right - will I need a new clutch? BigV SV Talk, Tuning & Tweaking 5 09-03-15 01:04 PM
Clutch Cable silent11 SV Talk, Tuning & Tweaking 4 29-09-09 02:44 PM
Clutch cable 21QUEST For Sale - SV's and SV related items 1 03-04-06 12:03 AM
