Old 04-06-21, 09:30 PM   #1
ChrisCurvyS
ChrisCurvyS's Avatar
Default First gen front brake lines
Looking for either the standard section of brake line running between the front right caliper and the divider thing under the headlight or a complete set of braided lines that would box off the issue of that line leaking. For first gen naked (lines for the S may well fit below the divider but not sure) Thanks in advance.
Red Suzuki GN 125 - sold
Black Yamaha XJR400 - sold
Current - 2000 SV650S curvy, red. 1969 VW Beetle for the snow.
ChrisCurvyS is offline   Reply With Quote
Old 05-06-21, 01:46 PM   #2
johnnyrod
johnnyrod's Avatar
Default Re: First gen front brake lines
Naked is only different above the splitter, same front end as the S but higher bars. All OEM stuff will be quite old now, I would just get a pair of braided with a double banjo at the top.
Old 05-06-21, 08:11 PM   #3
ChrisCurvyS
Many thanks for the reply and the info. I was going to go down the braided lines route however turns out the existing lines are fine - was actually the fork leaking down the back onto the part of the line where it is attached to the fork leg.
I'd foolishly not thought of that as the fork seals were done by a garage just last year and I've hardly ridden since.
Going to try one the Seal Mate tool before paying out for it again- checking the brake caliper seals led to seriously stuck pistons so I'm spending the MoT budget on a brake rebuild.
Front brake lines help! Eddie91 SV Talk, Tuning & Tweaking 30 18-04-16 09:01 PM
2 or 3 front brake lines? SV Mad SV Talk, Tuning & Tweaking 5 02-06-11 02:02 PM
front brake lines shane hill Mini-Twins 4 21-03-09 11:23 PM
GSXR Front end brake lines andyb SV Talk, Tuning & Tweaking 2 17-01-07 09:23 PM
HEL SS brake lines (front) for k3.k4 SV650s echomadman For Sale - SV's and SV related items 0 25-11-05 03:57 PM
