11-01-22, 09:29 PM | #1 |
Reboring
I've had rebores done before but never seen the process. Over to Allen Millyard and his 4 cylinder 550cc S1 two stroke...
https://www.youtube.com/watch?v=hp66Sx62Aj0
2016 SV650AL7 2023 GSX-8S |
11-01-22, 10:16 PM | #2 |
Re: Reboring
In awe of the guy
11-01-22, 10:35 PM | #3 |
Re: Reboring
That was a good watch. We even learned how to make cupcakes!
12-01-22, 08:53 PM | #4 |
Re: Reboring
Yes, great insight into the process.
I also like the concept of reuseable copper head gaskets that was part of this. Now all I need to understand is how to make pistons and valves and I might get somewhere with really restoring my FZ engines!
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue. RIP SV650 X curvy, crashed and written off December 2019. I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road. |
12-01-22, 09:01 PM | #5 |
Re: Reboring
I used to make my own copper head gaskets for my T140V 750 Bonnie, to replace the crap composite head gaskets which used to blow between the cylinders.
13-01-22, 08:55 PM | #6 | |
Re: Reboring
(I keep reading about needing extra ridges, often loops of wire in grooves, to compress the copper around the bore tops.)
13-01-22, 09:07 PM | #7 |
Re: Reboring
Yep, I just cut the sheet using a new composite gasket as a template and then annealed it. You could re- anneal and use four or five times before it got too out of shape, then it was time to make a new one. Had no problems with sealing.
13-01-22, 09:57 PM | #8 |
Re: Reboring
14-01-22, 08:57 PM | #9 | |
Re: Reboring
I feel an experiment coming on in the (hopefully) not too distant future. I have an FZ600 engine (aircooled in-line 4) that needs a rebuild and I'd like to get it running for sometime in the summer.
14-01-22, 09:55 PM | #10 |
Re: Reboring
I'd never thought about that but I can see how it would help. You could always make very thin copper washers to go around each bore, but they would not want to be any more than a few thou thick.
