Old 15-04-22, 06:03 AM   #1
Plutohora
Junior Member
Default Adjust throttle, less on/off switch like?
I'm new to biking but this is the third SV650 that I've ridden (and my own!).
The throttle is very switch like, on/off. As soon as I roll off the bike dives forward abit, there's no blending etc.
Any tips on how to make less harsh?
Plutohora is offline   Reply With Quote
Old 15-04-22, 10:29 AM   #2
Seeker
Seeker's Avatar
Default Re: Adjust throttle, less on/off switch like?
You didn't mention what year your bike is, I'm assuming a pointy but the year is important.
It may be that your TPS (Throttle Position Sensor) needs checking/setting:
https://forums.sv650.org/showthread.php?t=55459
The link shows the adjustment for an 03
I've not done it, hopefully someone that has (ie Bibio) will chime in.
Once the TPS is set then, if no better, the throttle bodies may need balancing and if it's a twin spark plug head it needs the Suzuki (SDS?) tool or a dealer for that.
2016 SV650AL7
2023 GSX-8S
Old 16-04-22, 09:27 AM   #3
mikerj
V-twins tend to have a lot of engine braking compared to IL4s of similar capacity, is this maybe what you are experiencing?
Old 16-04-22, 09:50 PM   #4
svenrico
svenrico's Avatar
My 2020 sv650a throttle action is ok .
svenrico is offline   Reply With Quote
Old 20-04-22, 12:54 PM   #5
EssEllTwo
Definitely do the TPS adjustment as per Seeker's link. Mine (2015 SL2) was a complete pig on slow corners and small roundabouts until I did this. Now I can roll the throttle off to a neutral position rather than the light switch accelerate or brake it was before.
EssEllTwo is offline   Reply With Quote
Old 20-04-22, 01:24 PM   #6
buy an IL4
Old 22-04-22, 08:28 PM   #7
johnnyrod
johnnyrod's Avatar
It's "character" I'm afraid
Old 23-04-22, 07:23 AM   #8
glang
You want to try my brothers Suzuki 1800 vee twin, its got loads of "character"!
Old 23-04-22, 10:40 AM   #9
Seeker
Seeker's Avatar
You should be able to modulate the throttle. If you need to gently slow to match traffic speed you should be able to ease off the throttle without it turning into engine braking. I've owned 2 curvies and now an 2016 AL7 and not had a problem with fine control on any of them.
2016 SV650AL7
2023 GSX-8S
GSXR 600/750 K6 K7 K8 K9 L0 Bazzaz ZFi-TC c/w Handlebar Map Select & TC Adjust switch & Quickshifter Talan For Sale - Other Bikes and General biking items 1 05-07-13 10:48 PM
Wanted - pointy naked rh switch, throttle cables and tube quik_d Stuff Wanted 0 28-07-12 08:10 AM
Please do not adjust your set... Ed Idle Banter 9 14-09-10 10:26 AM
Throttle/Kill Switch Casing JamesMio SV Talk, Tuning & Tweaking 7 19-12-08 01:58 PM
whole throttle and kill switch cluster anna Stuff Wanted 0 26-06-06 09:38 AM
