Old 15-04-22, 01:23 PM   #1
johnnyleitrim
Junior Member
johnnyleitrim's Avatar
Default trip meter resets after switching off bike
I just went for a 150(ish?) mile spin that I wanted to use my trip meter to measure (using trip a). I had to fuel the bike half way through, and when I turned the bike off and on again at the garage the trip meter had reset to 0.0
Is there a way to keep the trip meter values after the bike is switched off? (2018 SV650)
johnnyleitrim is offline   Reply With Quote
Old 15-04-22, 04:15 PM   #2
Seeker
Seeker's Avatar
Default Re: trip meter resets after switching off bike
I have the 2016 AL7 and mine doesn't do that. The only time my "Trip A" (or Trip B) resets is if I press and hold the "SEL" button for a couple of seconds which I do on each fill up. If I didn't press and hold the SEL button it would retain the (Trip) mileage setting.
Unfortunately, I cannot recall whether it loses the setting if the battery is disconnected.
2016 SV650AL7
2023 GSX-8S
Old 15-04-22, 06:38 PM   #3
glang
Does it lose the time as well?
Old 15-04-22, 07:35 PM   #4
johnnyleitrim
Junior Member
No, it doesn't lose time. Everything else seems fine, I'm just confused why the trip meters get reset to 0
Old 15-04-22, 08:45 PM   #5
daktulos
daktulos's Avatar
I've no idea about the 2018 SV, but as it's a bit modern, have you checked that you can't configure trip A to reset after a refuel? That's what my car does, and it's quite useful ... but set in the options somewhere.
daktulos is offline   Reply With Quote
Bike switching off when first gear is engaged after clutch adjustment rivsm SV Talk, Tuning & Tweaking 16 02-10-12 05:34 PM
What time is it? Clock always resets. r_bacon SV Talk, Tuning & Tweaking 6 09-01-12 01:55 PM
Switching from car to bike linco Idle Banter 4 21-06-06 08:02 AM
trip meter question triumph5ta SV Talk, Tuning & Tweaking 7 21-04-06 09:56 PM
Trip Meter Problem Framie SV Talk, Tuning & Tweaking 1 16-08-05 09:39 AM
