Old 10-06-23, 01:52 PM   #1
redtrummy
Default Flat battery again
Its done me again! Every now and again I forget to check that when applying the steering lock on Suzy, I turn the key one position too far and leave the park light on and a flat battery results. Luckily I was at my sons and we managed to do a bump start so I was able to ride home ok
redtrummy is offline   Reply With Quote
Old 30-06-23, 09:29 AM   #2
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Flat battery again
I hate that option and have done the same. Thieves snap the locks easy anyway so they aren't worth a damn IMHO. I use a disc lock and a portable little alarm secreted under my tank via magnets I stuck to it and use it when I park up for shopping etc.
Motorcycle portable alarm
As the Alarm doesn't have an on-off switch I have a little bit of card under the batteries and move that up to block one of the batteries contacting to save the battery life.
HTH
Old 30-06-23, 04:00 PM   #3
redtrummy
So I am not alone - thanks R1FF will take a look at the alarm -Thanks. I usually use a disc lock when out and about too.
Old 30-06-23, 06:01 PM   #4
R1ffR4ff
R1ffR4ff's Avatar
I stuck 4 of these on the bottom of the alarm. I roughed up the magnet's face s and the plastic so they bonded and used some Superglue and then a bit of twin pack epoxy to make sure
https://www.ebay.co.uk/itm/351416155...IAAOSw44BYff-9
SV flat battery - causes? Nicho..! SV Talk, Tuning & Tweaking 6 22-08-10 12:27 PM
Flat battery. Razor SV Talk, Tuning & Tweaking 21 28-07-10 04:23 PM
Flat battery. stu123 SV Talk, Tuning & Tweaking 1 17-11-09 09:58 PM
Help...flat battery KnightRider Bikes - Talk & Issues 27 12-11-07 02:44 PM
Flat battery cuffy SV Talk, Tuning & Tweaking 8 15-04-06 12:27 PM
