Old 13-06-23, 06:43 PM   #1
GDBD59
Default Coolant
Asking for a friend, honest!
A check's going to done on bike cooling system, so she'd like some coolant, but doesn't know what's in it.
Where is the most accessible point on a K1 to get a look at what's in it?
GDBD59 is offline   Reply With Quote
Old 13-06-23, 06:49 PM   #2
admin
John T
admin's Avatar
Default Re: Coolant
The overflow tank?
Sent from my moto g(50) using Tapatalk
Old 13-06-23, 07:46 PM   #3
GDBD59
Default Re: Coolant
Thanks, don't think I've seen any in it, but pointed a youtube vid at her.
Old 13-06-23, 08:36 PM   #4
admin
John T
admin's Avatar
Default Re: Coolant
There's a drain plug on the R/H side of the engine in the water pump if you want to replace the coolant. Plus you can look in the radiator via the cap.
Old 13-06-23, 08:40 PM   #5
GDBD59
Default Re: Coolant
Yeah that's what the vid showed. Tissue into the radiator to see the coolant type, or a dribble out the drain.
Old 14-06-23, 10:04 AM   #6
Default Re: Coolant
just drain, flush with water and renew with halfords pink readymix.
check that there is a small screw on the rad cap so dont try and force it off, somebody might have already taken it out.
remember to flush out the header tank.
fill via the rad cap first then close rad cap and top up the header tank.
once filled run bike till stat opens then top up as need be. dont overfill the header and just under the fill line is good enough.
Old 14-06-23, 02:13 PM   #7
glang
Default Re: Coolant
Dont forget it should be 50% concentration as recommended in the manual and isnt always easy to confirm on the contents labels...
Old 15-06-23, 01:15 PM   #8
GDBD59
Default Re: Coolant
Thanks chaps, info passed-on.
Old 05-07-23, 01:53 PM   #9
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Coolant
Don't forget to ,"Burp" the system. The procedure is in the WSM. Basically sit on the bike with the engine running and keep an eye on the coolant level in the rad. When the thermostat opens the coolant will flow around. Holding the bars and moving the bike left and right will allow air in the system to come to the top and escape. Failure to do so can cause engine over heating.
I recently changed over to this OAT coolant and have used other Mannol products,
https://www.ebay.co.uk/itm/304176715512
Full gallon delivered to the door. It has lowered my running temps by between 5 to 8 Deg C from my old silicate free car Glycol coolant I used to use.
HTH
Old 05-07-23, 03:22 PM   #10
glang
Default Re: Coolant
I like Mannol stuff but as far as I can see that coolant is 33% concentration and not the 50% recommended by Suzuki which as I say is quite difficult to find - what difference it makes I havent got a clue...
Coolant Aldoo SV Talk, Tuning & Tweaking 3 30-05-15 09:21 PM
Is this coolant ok? Scythe92 Bikes - Talk & Issues 2 17-03-12 10:54 PM
Coolant Gary C SV Talk, Tuning & Tweaking 3 14-08-09 11:29 AM
coolant top up steveg SV Talk, Tuning & Tweaking 10 19-01-09 04:19 PM
Sorry -coolant again tomjones2 SV Talk, Tuning & Tweaking 6 17-06-06 09:47 AM
