Old 29-05-24, 06:12 PM   #1
JohnSheep
Junior Member
Default Switch to swap between (restricted)A2 and unrestricted at roadside
Hi Guys
I’m in the UK on an a2 license and want to be able to switch between full power and restricted(47hp).
I only want to be able to switch to lower power easily and discretely in case I ‘went to a track’. (I know most people will say just don’t do it but I want to).
I've had a few ideas on how I could do this:
Running 2 ECU's in parallel
I was thinking about installing both a restricted ECU and a normal ECU in the bike and then having both connected at the same time. I would then wire 2 switches to kill power to one of the ECUs so one is 'dead' and won't respond.
Dual map PowerCommander (piggyback)
I have reservations about trying this because a PowerCommander is £450 and I'm not actually sure this will work.
I could have a PC with a map switcher, run 1 map with normal AFR(air-fuel ratio) and 1 map where I half the AFR to massively reduce power.
The problem is I'm not sure a PowerCommander offers enough adjustment to half the AFR so this may not work.
Switch to disable the ignition
This is the most crude approach - if the bike were to be seized I could flick a switch so the ignition is just no longer connected so it won't start so it can't be dyno'd.
However, I dont think this would go down too well...
JohnSheep is offline   Reply With Quote
Old 30-05-24, 06:31 AM   #2
Seeker
Seeker's Avatar
Default Re: Switch to swap between (restricted)A2 and unrestricted at roadside
Welcome!
I know nothing about restricted bikes - who checks to see if they are restricted or not?
I'm guessing the restricted ECU looks like the unrestricted one so couldn't you switch labels or swap the electronics between cases and keep the unrestricted installed permanently? If they're epoxy "potted" the latter wouldn't work.
Even if they suspected the substitution, would anybody bother to dyno it to check?
When do you get your license?
2016 SV650AL7
2023 GSX-8S
Old 30-05-24, 04:54 PM   #3
Biker Biggles
Biker Biggles's Avatar
I would think a load of odd wiring around the ecu would arouse suspicion and lead to investigation while just running the bike on a standard ecu would not be noticed by your average cop. Very different if you had a crash and the insurance got involved though.
Old 31-05-24, 11:09 AM   #4
garynortheast
garynortheast's Avatar
Personally I'd just bite the bullet and put up with the restricted version for a while. You're not going to be on it for that long, and the consequences of being caught, however remote, could have a really serious impact on your insurance premiums. Insurance costs are bad enough as it is without risking them being jacked up any further!
Blue Curvy S with over 111,000 miles and still going strong.
Old 31-05-24, 04:02 PM   #5
redtrummy
I agree Gary
redtrummy is offline   Reply With Quote
Swap K5 full power ECU for restricted? BradW314 For Sale - SV's and SV related items 2 02-09-12 02:00 PM
Restricted vs. Unrestricted? XmisterIS SV Talk, Tuning & Tweaking 3 10-05-10 11:14 PM
Coming soon to a roadside near you. the_lone_wolf Bikes - Talk & Issues 79 18-02-10 10:36 PM
Newbie question - Restricted ECU swap? KebabDan Bikes - Talk & Issues 8 20-09-08 07:03 PM
Roadside safety RingDing Bikes - Talk & Issues 5 06-03-08 09:42 AM
