Old 16-09-04, 11:24 AM   #1
rukus
Default throttle synchronising how to...
Hi Everyone,
I balanced my throttles yesterday using the carbtune II. Unfortunately time was a bit tight so I didn't have time to take notes and photo's
I'm probably going to go through the process on the weekend again if the weathers ok, so will do the photo shoot then.
BTW, my throttles were well out of sync and after balancing the bike is runing a dream, the power has returned and all is smmmoooooooth
Carbtune II is http://www.carbtune.com is qbout 60 quid with a very good quality case, service from the company is impeccable (next day delivery even with a change in order). and is extremely easy to use Highly recommended.
Mark
Old 21-09-04, 07:32 PM   #2
ANDYTEE
Default Carb balancing
Thanks for the useful info on Carbtune. In the Haynes manual it say you need to apply a vacuum to the fuel tap to keep it open while adjusting the carbs. How did you do this Is it in the Carbtune kit
Want to try this, this weekend as mine is not running as smooth as I think it should.
AndyTee
Old 21-09-04, 08:53 PM   #3
Andy4us
why bother
http://www.bluepoof.com/motorcycles/...svs_carb_sync/
Andy
Old 21-09-04, 09:27 PM   #4
rukus
why bother... cos I'm working on the K3 here which is different!!
AndyTee, I can't answer your question I'm afraid. This step isn't required on the K3... sorry
Old 22-09-04, 02:56 PM   #5
Carsick
I'm pretty sure I saw a guide in the FAQ here for setting the throttle sensor properly on the K3.
What exactly does the carbtune do on a fuel injected bike?
Old 22-09-04, 03:50 PM   #6
weegaz22
synchronises the throttle bodies
Old 22-09-04, 03:59 PM   #7
Carsick
more specifically I meant what does it connect to. I know that normally you'd connect vacumn gauges to the carbs so you could balance them, but what vacumn are they connected to on a fuel injected machine?
Old 22-09-04, 04:05 PM   #8
weegaz22
the throttle bodies do have a vacumn, but as i have the older version sv i cant tell you specifically where they are, there will be vacumn hoses on them for balancing somewhere
Old 23-09-04, 11:24 AM   #9
johnnyrod
johnnyrod's Avatar
To keep the fuel tap open I usually tee this into the carb that it is normally fitted to. Keep all the lengths of tubing as close as you can to the same lengths as a matter of course, so the vacuums change at the same rate. You'll have to find the tubing and tee piece yourself though.
No used the Carbtune but rukus and others say it's good. Don't use the gauges on the bluepoof site in the pictures, I tried these before and they're a waste of money!
Old 23-09-04, 08:33 PM   #10
ANDYTEE
Oh joy - sounds like the 5 minute job just got much bigger!! I followed Andy4us' tip and read the bluepoof article which makes it sound like an all weekend job - thanks for the tips on fuel tap opening from johnnyrod. Hope it will all be worth while.
r6 throttle mod where has it gone? ianofbhills SV Talk, Tuning & Tweaking 12 12-07-09 09:04 AM
Synchronising with MS Access andyb Idle Banter 17 30-04-08 08:08 PM
r6 throttle 01 sv650s Stuff Wanted 14 25-01-07 01:45 PM
r6 throttle antony SV Talk, Tuning & Tweaking 4 24-01-07 11:21 PM
throttle? oldsvrider SV Talk, Tuning & Tweaking 3 12-01-07 08:36 AM
