Old 14-10-04, 08:09 AM   #1
454697819
Default JHS Stage 3 Forks!
Any one got them, is just progressive springs with spacers and adjustable caps with heavier fork oil!
Not bad at 136 quid,
Front end needs sorting asap!
Thoughts please??
Old 14-10-04, 11:03 AM   #2
mysteryjimbo
I'd like to know this also.
Old 14-10-04, 11:59 AM   #3
johnnyrod
johnnyrod's Avatar
You definitely want the stiffer springs, and I think also the adjuster caps so you can get the preload right. As for the heavier oil... this is always a moot point, some people think it's the way forward, some people think it isn't worth it. The damping of the forks is, IMHO, fine on rebound but not enough on compression. The JHS stage 4 forks modify this, or you can try emulators (my thumbs up). The jury still seems to be out on the oil, but the stiffer springs and correctly-set preload really help. While you're on to JHS, get the longer dogbones for the rear cos (a) worth it for £15 and (b) with stiffer forks you might find the front is a little higher so these will counteract it.
Stage 1 ,3 ect jet kits....stage 2? Torn-Thorax SV Talk, Tuning & Tweaking 11 05-03-07 07:36 PM
MCN: Dakar Rally: Stage 10 NewsBot News 0 20-01-07 12:50 AM
who has JHS stage 2 or factory pro stage 2? 01 sv650s SV Talk, Tuning & Tweaking 1 15-12-06 08:12 PM
Next stage after can? Carl SV Talk, Tuning & Tweaking 13 15-06-05 08:33 AM
JHS stage II cams for $200 Ziguy SV Talk, Tuning & Tweaking 75 19-03-05 05:18 PM
