Old 15-10-04, 12:25 PM   #1
ArtyLady
Default fitting a new end can
Old 15-10-04, 12:33 PM   #2
Raf
Default Re: fitting a new end can
Originally Posted by mumstoy
I want to fit a scorpion end can on my sv but have been told that I have to cut off std exhaust first is this right and if so how easy is it to do and can you put std can back on
I've got a Scorpion Carbon Fibre Race can on my SV and I had to cut off the pipe. The race can also comes with a smaller link pipe so that you can fit the orginal can for those MOT moments. Bear in mind that if you get a road legal can you don't need to fit the original back, even for MOTs.
As a rule of thumb you always have to cut the original exhaust to fit a new can on the SV, unless it is a full system.
Old 15-10-04, 12:44 PM   #3
splke
splke's Avatar
Piece of p*@s mate.
50mm back from the weld
hacksaw like a demon
Robert is your mums bro
:P
splke is offline   Reply With Quote
Old 15-10-04, 12:46 PM   #4
M65
Or get a 3/4 system that will bolt straight onto the downpipes
Old 19-10-04, 11:57 AM   #5
davy
Hi, I fitted a Viper can to my SV, had to cut the pipe as usual. But the adaptor pipe for the can is no good to fit the original can back on as the dia reduces. You need a 55mm pipe ( I think) to fit the original can back on for the MOT test. I can't locate anyone that does pipe this size and my MOT is looming in a few months.
Davy
Old 19-10-04, 12:26 PM   #6
Potts
I fitted a scorpion road legal can with removable baffle earlier in the summer. It is fairly straight forward but a hacksaw will keep you sawing for an age. I used an angle grinder and moved the footpeg out of the way to get in without damaging the frame.
The scorpion can comes with the instructions and parts so it is no worries.
Remember to look at the bike from the rear when you have fitted it to make sure it looks straight etc. as you have a little play in it before fully tightening things up. This is purely cosmetic of-course but if you go for the oval can it does make a difference.
If you want a really big grin you could start the engine when you've cut the stock can off and before you fit the race can. You'll giggle like a school boy but only do it for a very short period as not sure whether it causes any damage to bike, but am sure it will annoy your neighbours.
Old 19-10-04, 12:31 PM   #7
Viney
I have a hacksaw and am willing to travel!
Old 19-10-04, 02:06 PM   #8
Shinsei Jutsu
Can you travel my way (or me to you (I'm easy)) with the hacksaw and shotgun?! Worth a try!
Old 19-10-04, 04:00 PM   #9
Cloggsy
many thanks for all your advice guys - hubby has been well briefed and is armed with angle grinder at the ready for when can arrives
It'll all end in tears... Be very carful with an angle grinder
Old 19-10-04, 07:19 PM   #10
mattyL
would anyone happen to know if a scorpion road legal is same siz e as scorpion race can as I may have to swap soon for MOT?
HID fitting (yes again, sorry) Brettus SV Talk, Tuning & Tweaking 65 24-01-09 06:45 PM
R&G Fitting cb5_keith SV Talk, Tuning & Tweaking 14 25-06-08 11:53 AM
DIY Can Fitting Jackhammer SV Talk, Tuning & Tweaking 14 15-02-08 01:12 PM
Help fitting my new can.. 5v5 rider SV Talk, Tuning & Tweaking 17 03-07-06 08:16 PM
Fitting CCC cuffy SV Talk, Tuning & Tweaking 57 27-01-06 09:36 PM
