Old 15-10-04, 12:30 PM   #1
Iansv
Default Problem, help needed
Got a few symptoms of a problem with the bike, just wanted to pick some brains......
Seems to be losing power, all over the rev range in all gears....
Only started happenning after the std can went back on because of an MOT, Its been silicone sealed on and I can't shift it atm so can't check if exhaust is the prob...
Mainly get it when trying to accelerate hard, for example m25 yesterday traffic picked up the pace so I tried to accelerate quite hard and the bike just stuttered as if there was no power left... Is there anything I can check?
Its coming upto 12k service so wondered if it may be the plugs? also thought it could be exhaust as i've got a rene airkit and maybe its being stifled ?
well any help is appreciated cos its getting annoying now and I don't want to go on the end of year rideout like it
Old 15-10-04, 12:57 PM   #2
BillyC
BillyC's Avatar
It sounds like the mixture is too rich when you crank that throttle... have you made any adjustments to your carbs?
Old 15-10-04, 01:14 PM   #3
chazzyb
Could be weak sparks. Certainly I have had similar symptoms with other bikes and it's been sparks.
However, IKBA.
Old 15-10-04, 02:36 PM   #4
Iansv
well I have been getting crap mileage but the airkit hasn't been touched since it was put in....
Plugs i agree it could be, will have to try changing em
Old 15-10-04, 02:46 PM   #5
Tris
If the standard can has'nt been on for a while, perhaps it's collapsed internally, restricting the flow of exhaust?
Old 15-10-04, 04:19 PM   #6
rukus
SOunds like maybe carb icing? is it early in the morning or late at night?
didn't think it was quite that cold just yet though!!!
Old 15-10-04, 08:10 PM   #7
Iansv
defo not carb icing its been doing it 2 weeks all the time
Old 15-10-04, 10:17 PM   #8
H-Gerickemark
hopeyou get it sorted
Old 15-10-04, 10:53 PM   #9
rukus
Aah... erm SV325?? I guess knackered sparks or leads, or the old water in the front plug?
Not that I'm a mechanic or anything! Hope you get it straightened out dude!
Old 15-10-04, 10:56 PM   #10
H-Gerickemark
sorry left a post an dont quite know why the little yellow man is gesturing about.
yes you can tell i am fairly new.
sorrrrrrryyyyy.
mark
sv 650 starting problem help needed aermacchi SV Talk, Tuning & Tweaking 4 12-02-08 10:27 PM
Help needed winter problem aday2end SV Talk, Tuning & Tweaking 10 24-02-07 07:20 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
major running problem. Suggestions needed mikemm SV Talk, Tuning & Tweaking 39 23-11-05 08:01 PM
