Old 16-10-04, 10:52 AM   #1
Cloggsy
Default K3 SVS - as dead as a Dodo... Sorted now thanks!!!
I've fitted the new LED sidelights to my bike & basically it's dead - Nothing's lighting up on the dash or anything
HELP
Old 16-10-04, 11:02 AM   #2
StevePJ
Check you havent blown the main fuse. Not sure where it is located on a K3, but should be near the battery. Your manual should tell you. Don't mean to sound rude, but did you disconnect the battery when fitting the lights. If so, have you put the wires back on.
Sometimes it's the simplest things.
Old 16-10-04, 11:06 AM   #3
snoopy
Don't worry, you've just blown the main fuse. First test the indicators resistance using a multimeter. If its close to zero you've a short somewhere from wire to indicator and you'll need to fix before you change the fuse.
Fuses are under the front seat (K2). If you need the bike to get a fuse from shop you can stick some foil in to replace the fuse BUT THIS WILL BE VERY DANGEROUS if you still have a short so MAKE SURE you fix that first.
As a side note I've also found on the K2 you can short the inidcators and electrics will go dead but unshorting and resetting (key out then in) brings electrics back. That means electronic trip in the flasher unit.
A.
Old 16-10-04, 12:05 PM   #4
Cloggsy
Done it... You were both right... I'd blown one of the 30 amp fuses - Replaced it now & it's sorted
Old 16-10-04, 12:16 PM   #5
StevePJ
Always remember to disconnect the battery when carrying out any electrical work..
I bet you panicked when there was nothing eh?
You're face must have been a picture. :P
Just thank god it was a simple cheap fix...
Old 16-10-04, 01:18 PM   #6
Cloggsy
Nah... Why do it the easy way, when the hard way is much more fun
Old 16-10-04, 01:39 PM   #7
SV-Sexy-virgin?
i did that striped an indicator wire accidently and it caused great confusion rusulting in 13 fuses for the bike and 15 alarm fuses extremely ****ed off nabours (it was 11 oclock wudnt stop goin off) problem is my fuss were just ickle and the 1ns i had were the right ampage but the rong physical size SCISSORS !!!! judt trim down these fuse prongs wallah !!
well hats my just woke up ramble done then
Old 16-10-04, 01:48 PM   #8
Cloggsy
Originally Posted by SV-Sexy-virgin?
i did that striped an indicator wire accidently and it caused great confusion rusulting in 13 fuses for the bike and 15 alarm fuses extremely p*ssed off nabours (it was 11 oclock wudnt stop goin off) problem is my fuss were just ickle and the 1ns i had were the right ampage but the rong physical size SCISSORS !!!! judt trim down these fuse prongs wallah !!
Eh
Old 16-10-04, 01:59 PM   #9
Jabba
Eh
Think he meant that you just put the togglemode into the waggle-flange..............
Old 18-10-04, 10:16 AM   #10
Cloggsy
Eh
The dangers of drinking Tennants Super on a lunchtime
Sorted, cheers northwind Stuff Wanted 1 31-03-06 09:39 PM
Panniers *Sorted* PoRk ChOp Stuff Wanted 1 24-01-06 12:02 PM
sorted hall13uk For Sale - SV's and SV related items 22 10-01-06 10:02 PM
SORTED IGNOR PLEASE Diveboy SV Talk, Tuning & Tweaking 0 21-11-05 10:27 AM
