Old 19-10-04, 03:34 PM   #1
jim6800
Default Butterfingers!
Dropped the SV in the car park at work today. Went down exhaust side, of course. Two technical-ish queries about the damage.
1. My beautiful Remus end can is slightly damaged. The hoop round the collector-end is pushed a little out of line. When I put my hand down next to it I can feel a little gas escaping (firing out the other way). Is this something I should worry about, and if so can I fix it with a gasket sealant?
2. The rear brake lever and footpeg are a wee bit bent too. I'm going to try and bend'em back, but if that fails, which years will fit an SV650K3? I'm guessing 2003 and 2004.
And the cheapo Motrax bobbins do work: the radiator is completely untarnished. On the other hand I probably wouldn't be replacing the brake lever if I had fitted the R&Gs.
Old 21-10-04, 04:58 PM   #2
BaggaZee
I keep reading about people using silicon sealant to seal exhaust leaks, I'd have thought it wouldn't cope with the heat too well. Can anyone shed light on this? It might be your answer...
Old 21-10-04, 06:10 PM   #3
Guy H
You can get fire resistant silicone which lasts much longer, but ordinary builders' silicone will do the job for a while. You can also get a silicone that they use to seal some gubbins in ovens but that's expensive as you have to get it from oven manufacturers / repairers
Old 22-10-04, 12:50 AM   #4
johnlowe
Default Re: Butterfingers!
I did much the same with my SV on the day I collected it from the dealer except that it went down on the other side. I was doing a full-lock turn in a car park when down it went. It was probably a combination of the shiny new tyres (only 10 miles on the clock) and the slimy mud coating on the car park (well that's my excuse!).
I managed to plant my left foot but couldn't stop it going down. To my amazement there wasn't so much of a scratch on the bike apart from a slight bend on the gear change pedal.
Old 22-10-04, 07:48 AM   #5
Scoobs
Don't worry about the gas. I had a low speed spill on my bike, 20 - 30mph, and ground a hole in my standard pipe. I had the bike dynoed and the fuelling was still spot on (air / fuel mix). Rode it like that for 6 months until I could afford a new can. No bother!
