Old 03-11-04, 10:02 PM   #1
Goffa
Default Thank You
Hi all Thanks for your help i have now fixed the problem which was with my starter solaniod so thankyou all very much for your responoses .
Old 03-11-04, 10:32 PM   #2
Grinch
Sounds like the ignition relay is gone... if it keeps blowing fuses. If its still in warenty then I would have a word with suzuki. Else take it out and give it a 'whack' until you can get another.
Old 04-11-04, 03:17 AM   #3
rictus01
rictus01's Avatar
that would be the loom rubbing then
Check where it goes around the rear sub-frame, you shouldn't just replace fuses, without finding out why they go.
Cheers Mark.
Old 04-11-04, 08:13 AM   #4
fizzwheel
fizzwheel's Avatar
Cheers Mark.
That happened to me except the loom was rubbing round by the headstock and every time I turned the bike to the left it would smoke from under the fuel tank on the right hand side
Old 04-11-04, 11:00 AM   #5
Goffa
Default Thank u all
Thanx for all ur replys so far i will check out these sugestions when i finsh work and put a new post on to let u no how i get on thanks again
