Old 06-11-04, 07:03 AM   #1
daddy_sperm
Default Tail Riser
Hiya,
I read in a magazine (unfortunately I cant find the magazine which covered all aspects of tuning the sv) about tail risers to make the back 15mm higher. I have a K4 and think its a bit to low so was hoping to source and fit one of these to my baby and bring the height up to that of the K3.
Any help greatly appreciated
Darryl
Old 06-11-04, 09:39 AM   #2
rictus01
rictus01's Avatar
"dog bones"
if you change the suspension linkage plates "dog bones" you can raise or lower as much as you like , without changing the rear suspension action.
if you're after only a small amount you maybe able to just add a bit more pre=load to the rear shock to get the same result.
Cheers Mark.
Old 06-11-04, 04:11 PM   #3
daddy_sperm
Thanks for replying where can i get longer dog bones then ?
cheers Darryl
Old 06-11-04, 04:18 PM   #4
Jp
Originally Posted by rictus01
"dog bones"
Cheers Mark.
Is that like "wish bones" on cars?
Old 06-11-04, 05:24 PM   #5
Iansv
JHS Sell them.... Some people make their own
Old 06-11-04, 11:14 PM   #6
Wiltshire7
is the k3 taller than the k4 then?
Old 06-11-04, 11:17 PM   #7
Cloggsy
Yup
Old 06-11-04, 11:40 PM   #8
Anyone know if it's trye that Hayabusa ones work to raise the SV by a cm or so? I've heard it a couple of times but never tried it...
Old 07-11-04, 08:49 AM   #9
daddy_sperm
Does fitting one of these effect the handling ??
Surely raising the tail will have the same effect as dropping the forks down the yokes and make it turn quicker? Or am I way of the mark?
Old 07-11-04, 12:04 PM   #10
rictus01
rictus01's Avatar
no you're right, but changing the dog bones has the advantage of not decreasing ground clearance.
I make my own, a couple of bit of flay bar, rounded at the ends. easy to do.
shorter = higher
Longer = lower
Never tried the Hayabusa option, but if they are shorter than the SV ones then it should work.
Cheers Mark.
Riser bars on the SV650S (curvy) Grinch SV Talk, Tuning & Tweaking 13 26-07-09 10:28 PM
LSL Handlebar Riser Kit or similar wanted redeye-dv Stuff Wanted 0 20-05-09 06:55 PM
Bar riser kits nigelv68 SV Talk, Tuning & Tweaking 6 26-10-08 07:57 PM
Cheap riser for SV650s Bars?? svscratcha SV Talk, Tuning & Tweaking 6 20-08-07 05:33 PM
Banditmania riser clip-ons tigerprof SV Talk, Tuning & Tweaking 0 13-10-06 03:46 PM
