Old 03-12-04, 08:44 AM   #1
Scoobs
Default I've got two hours spare this afternoon.....
.....is it enough time to fit a Double Bubble?
Is it difficult to do?
Cheers all!
Old 03-12-04, 08:58 AM   #2
Viney
about 10 mins absolute max. You will need a 3mm allen key, a philips screw driver, a little wd40 or similar, and possibly a small pair of pliers.
Undo the lower two 3mm allen bolts (The rubber mounted captive nut may spin around hence the pliars to hold it still)
Take off the trim behind the mirrors (Phillips screwdriver)
Take out screen
Transfer the rubber mounted captive nuts from the old screen and /or fairing.
Put new screen in place.
Coat the rubber things with a little wd/furniture polish, screw the screws back in about 1/4 turn and push through the screen and the holes in fairing(Leaving the top flangeoutside the bodywork, between the screw head and fairing)
Tighten to touch
Replac mirror covers.
Job done
Old 03-12-04, 09:36 AM   #3
Clunk
Oh yes, I remember that's the easy bit, not fiddly at all
Old 03-12-04, 10:05 AM   #4
Scoobs
Excellent.
Cheers for the advice fellas.
Old 03-12-04, 10:13 AM   #5
Viney
It not once you put some form of lubricant on the rubber
Old 03-12-04, 11:19 AM   #6
Iansv
even I did it in 10-15 minutes the first time, took about 5 the next time
Old 03-12-04, 11:28 AM   #7
Viney
Ian, we are talking about changing screens mate on an SV!
Old 03-12-04, 12:15 PM   #8
Grinch
Am I liable to get a call later today asking for help as you can't get the thing in.. (miss quote heaven)
Old 03-12-04, 12:39 PM   #9
Scoobs
Distinct possibility
Old 03-12-04, 12:47 PM   #10
Warren
easy peasy. i got 2 hours free today - can i fit new brake pads ?
50 free Hours with AOL Richie Idle Banter 6 01-11-08 08:59 AM
These will keep you amused for hours :) Blue_SV650S Idle Banter 0 14-05-08 04:59 PM
4 hours Dicky Ticker The Essex Lounge 3 06-09-06 11:30 AM
Off to France in 24 hours..... 454697819 Bikes - Talk & Issues 7 13-05-06 09:43 AM
Two hours to go... markfc SV Talk, Tuning & Tweaking 5 04-03-05 02:15 PM
