Old 05-12-04, 02:34 AM   #1
Default Possibly stupid question re cam swap
So the big day approaches for the K3 cam swap, and I suddenly wondered, do you need to run cams in? It's a moving mechanical part so I suppose there could be a wear issue there. I'm assuming that I don't, but it'd be nice to know...
Old 05-12-04, 08:13 AM   #2
chutz
Dunno, but once you've got the K3 cams are you gonna get the K3 frame,rear light and all the other parts to make your curvy bike sexy?
Old 05-12-04, 03:11 PM   #3
No, I shall be happy with 4 bhp more at the rear wheel for half the cost and paint that doesn't rub off when you sneeze But I still wish I could get the LED tail lights, they're the only bit of the spiky bike I like...
Old 05-12-04, 03:30 PM   #4
Cloggsy
Old 05-12-04, 05:22 PM   #5
embee
embee's Avatar
Ref. cams and followers,
it's generally not advised to run new and old cams/followers together, though you can usually get away with it. The reason is that the contact stresses are pretty high as the cam goes over full lift, and there is a reversal of oil entrainment (getting technical ) where the cam reaches the edge of the follower (maximum valve velocity).
These conditions can result in what's termed boundary lubrication where you're simply relying on a few molecules of oil to keep the metal apart rather than a nice thick oil film generated by the surfaces sliding over each other.
New parts are manufactured with surfaces which bed together during the first few hours running, like rings and bores, but retain enough oil to avoid scuffing.
If you're putting used and new parts together, use some very fine silicon carbide paper (wet&dry) to put a cross-hatch pattern on the cam/follower surface (like cylinder honing), at 45deg to the direction of sliding. Buckets/biscuit shims usually have a similar spiral type hone pattern. This gives a reservoir for the oil to sit in. Wash parts very thoroughly afterwards, put tape over drillings etc to avoid grit getting into oilways.
For assembly use either special cam assembly paste available from decent tuning places, or a small amount of EP type gear oil will provide protection for a short while after start-up. Whatever you use, make sure everything is oiled well.
Lubrication is worst and stresses highest at low speed like idle, so once the engine is started, increase the revs to around 3000rpm as soon as you can. Other than that there's little you can do for valve train other than give the engine a few hours running around mid-revs. Don't leave it idling.
Old 05-12-04, 10:23 PM   #6
Marvellous, cheers.
Quick, (possibly stupid) question if I may? stroppygob SV Talk, Tuning & Tweaking 12 26-02-09 01:39 PM
Possibly a stupid question but it's bugging me... feeelthapowah Thames Valley 12 05-03-08 05:44 PM
Ok stupid question aarond SV Talk, Tuning & Tweaking 2 19-05-07 04:47 PM
Possibly daft insurance question...bike values the white rabbit Bikes - Talk & Issues 7 03-02-07 06:05 PM
oh to swap or not to swap that is the question.. DrPain Bikes - Talk & Issues 27 25-04-05 02:48 PM
