Old 10-12-04, 05:35 AM   #1
grant arbuthnot
Default running on one cylinder in slow right hand bend
My SV650 of 2000 occasionally fails to deliver when asked in slow tight right hand bends. This behaviour is intermittent and appears to be less likely when the bike has just been serviced. It is most likely to occur turning right from standstill at an intersection; this is sometimes inconvenient in relation to other (larger) vehicles.
There are no modifications to the engine.
Has anyone else had this experience?
Is there a solution?
Grant
Sydney
Australia
Old 10-12-04, 10:19 AM   #2
zx6man
could it be the sidestand switch causing problems???
Old 10-12-04, 02:02 PM   #3
Scooby Drew
It sounds like the engine is starving fuel. If it has carbs, the float bowl could be set wrong which means that when the bike is leaned at a certain angle, there is not enough fuel in hte carb and because the engine is starting from idle (when taking off) there is no velocity in the fuel air mixture to create enough of a vacuum to pull more through.
That's a guess...
Old 10-12-04, 03:32 PM   #4
plot241
I'd have to agree with Scooby.
I had a similar problem with my K1, every time the bike went off centre it would stall on me. In a straight line it was fine, but lean it over and it would stall. Bit of a problem if you wanted to go around a corner!
Took it into the garage they emptied and reset the float bowls and I haven't had a problem since, and that was 9 months (3,500 miles) ago.
Gary
K6 running on one cylinder. Smoggy SV Talk, Tuning & Tweaking 29 16-03-09 11:03 PM
Too much oil on the K&N, now running on 1 cylinder... Troy Bikes - Talk & Issues 26 24-07-08 06:21 AM
RUNNING ON 1 CYLINDER jmsvuk SV Talk, Tuning & Tweaking 2 13-02-06 04:53 PM
Help - running on 1 cylinder buckstone SV Talk, Tuning & Tweaking 3 23-01-06 05:55 PM
1 cylinder running Scoobs SV Talk, Tuning & Tweaking 6 11-02-05 10:05 PM
