Old 27-12-04, 09:52 PM   #1
shutdown
Default squeaking brakes
if the brakes squeal when i pull the front one does this mean they are on the way out or something else?
Old 28-12-04, 12:07 AM   #2
Stig
It could be a sign that the brakes are worn. If I am not mistaken they are designed to "squeal" when they are due for replacement. But it could also just be crap and stuff on the disks. It is possible for them to squeal if it hasn't been run for a few days and a bit of rust has developed on the disks. A few braking manoeuvres will soon rid you of the squeal. I guess the easiest way is a visual check of the pads, and the fluid level in the reservoir.
Old 28-12-04, 12:08 AM   #3
Valman
My rear brakes squeal even if I dab them and my bike is brand new and I've only done about 400 miles on it, so I don't think it means they're on the way out. They do help me stop fine and it is going in for its first service very soon anyway so I wasn't too worried as I was going to let the dealer fix it. I do remember reading something in the handbook about taking some sandpaper to the pads and disks on this but I'm not exactly sure.
Old 28-12-04, 09:18 AM   #4
fraser01
my bike is new and my back brake squeaks as well...annoying...
Regards
Fraser
Old 28-12-04, 09:36 AM   #5
wheelnut
Squealing brakes are normally due to the pads moving against the piston and / or the backing plates.
To cure it, remove the pads and apply some copper grease to the back of the pad, Yes the Back make sure the edges of the pads are free from crud too, When the pads are out use an aerosol brake cleaner, one which evaporates rather than the oily based cleaners.
Make sure you do not get grease on the discs or the friction material, because that normally ends in a huge bang
Sometimes if you fit new pads against worn discs it may squeal too, but normally this will wear off as the pads bed in
squeaking and crazy speed count Redfox SV Talk, Tuning & Tweaking 2 31-10-08 07:17 PM
clutch squeaking when warm ricky SV Talk, Tuning & Tweaking 7 11-09-08 04:12 PM
Better brakes rob13 SV Talk, Tuning & Tweaking 12 21-09-07 04:17 PM
Brakes! Phantomtek SV Talk, Tuning & Tweaking 21 14-09-06 03:01 PM
Brakes morty SV Talk, Tuning & Tweaking 18 29-08-05 09:33 AM
