Old 03-01-05, 06:15 PM   #1
kebabman
Default Where to get suspension work done?
Hi Guys, was wondering if anyone could recommend anywhere in the Oxfordshire area that could put some uprated springs + oil in my forks, and set the suspension up.
Cheers, Alex
Old 03-01-05, 06:26 PM   #2
Flamin_Squirrel
Do it yourself. If you're not sure what you're doing, people on here can help.
Old 03-01-05, 06:47 PM   #3
Patch
If you want the best job possible doing take it to MH Racing in Calne. The guy really knows his stuff I use him to rebuild the Ohlins on the VFR
http://www.mhracing.com/
Old 04-01-05, 01:48 AM   #4
For what you want done though, it's perfectly possible that you could do the best possible job... It's dead, dead easy. The pros would do you much better work with a more adjustable setup, but assuming you've decided what oil you want there's nothing they can do that you won't.
Old 09-01-05, 02:35 PM   #5
kebabman
I could give it a go, but, other than a rear paddock stand which isn't much help, I don't have any way to raise the bike off the ground. Was looking at 'Adam's SV' pages at the guide and thought I could have a go, I guess I'm just nervous taking it all apart
What weight oil is recommended? I've got a K4 GSXR-1000 shock to go on the rear...
Cheers for the advice
Old 09-01-05, 02:38 PM   #6
Flamin_Squirrel
Where 'bouts do you live?
Old 09-01-05, 05:42 PM   #7
kebabman
I live in a village about 5 miles west of Oxford on the A40.
Old 09-01-05, 05:54 PM   #8
You want an Abba stand... Bloody brilliant things. I probably use mine more than most but even so I reckon it had proved its worth after one shock swap and the first time I worked on the front end, just from stability and safety. You can do the front end just with a rear stand and bottle jack, but even with extra supports/roping I'd still be paranoid of it falling.
Not cheap, sadly, but you can't have everything.
Old 09-01-05, 09:32 PM   #9
Flamin_Squirrel
Ah, bit far to borrow my stand then.
I've go an NWS stand, better than the ABBA stand because its got a backstop so it cant move at all
Good guy for suspension work & SV mods in Glasgow zigrat SV Ecosse 5 20-05-09 07:28 PM
Suspension help Endellion SV Talk, Tuning & Tweaking 6 24-04-08 09:54 PM
suspension ljharmitt SV Talk, Tuning & Tweaking 5 07-11-07 08:02 PM
Suspension chris SVK3 Bikes - Talk & Issues 0 03-07-05 06:20 PM
suspension Shinsei Jutsu SV Talk, Tuning & Tweaking 9 29-01-05 06:01 PM
