Old 04-01-05, 11:40 AM   #1
snoopy
Default Lost 1st gear
Ladies and gents I've lost first gear. If bike is in neutral it will downshift to first but when coming to a stop it will openly refuse to go into first gear. The lever travels all the way down and there is no clunk. It doesn't feel like its trying to engage its like there is nothing there and its travelling past first without engaging.
So I'm currently pulling away in second. I've also found that if in second and have give it some throttle it will then downshift to first.
Have adjusted clutch cable so it can't be that. I've also just changed oil and its only started happening after that, though as the cause i'm doubtful.
Ideas?
Old 04-01-05, 11:43 AM   #2
zx6man
maybe the clutch has been adjusted too much?. Have you changed the types of Oil?? semi to full etc or mineral/synthetic???
Old 04-01-05, 11:47 AM   #3
Itching 2 go
also chech chain tention. the oyher thing you could try is whilst trying to select first ie hold your foot on the lever slowly release the clutch lever slightly that sometimes doesit, obviously hold the brake at this point also. and dont feed the clutch all the way out
Old 04-01-05, 11:51 AM   #4
BillyC
BillyC's Avatar
What he said
Old 04-01-05, 12:24 PM   #5
jambo
jambo's Avatar
Try also rolling the bike back or forward a bit with your right foot while trying to click down into 1st with the left. a foot or so of travel should be fine, gearboxes can be sensitive to chain tention and you may find this rolling solves it. Also try and get into the habit of changing down while still rolling up to the place you intend to stop rather than trying to change once you're stationary.
Old 04-01-05, 12:24 PM   #6
BillyC
BillyC's Avatar
... also, sounds like you might have overfilled the oil! Check it very carefully!
Old 04-01-05, 12:39 PM   #7
snoopy
Its Semi, still 10W40 but seems a lot thinner viscosity than the stuff I was using before. Castrol GTX from Morries at just £9.99 for 5 litres.
Old 04-01-05, 12:40 PM   #8
snoopy
I do, and it won't find first! I end up stopping in second and pulling off in second
Chain tension is fine though I could have overfilled on the oil, I shall check this later. Im really thinking physical damage as this has never happened before - it seems to be travelling past first.
Old 04-01-05, 12:43 PM   #9
Mike1234
Sounds like the clutch adjustment to me.
Try adjusting more slack in to the lever and see if that solves the problem.
Old 04-01-05, 12:44 PM   #10
Itching 2 go
or possibly the scew adjustor behind the front sprocket cover is fooked. it was on my TL changed it and it cured the problem for me
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Gear change problem-can't get past 2nd gear muzikill SV Talk, Tuning & Tweaking 8 14-03-10 10:10 PM
Gear change problem-can't get past 2nd gear muzikill SV Ecosse 8 13-09-07 07:45 PM
