Old 06-01-05, 11:27 AM   #1
shutdown
Default wet weather engine
Is it normal for the engine to be juddery when it's belting down with rain?
I got caught in a downpour on the A38 last night and noticed the engine wasn't as reponsive and didn't sound like it was firing properly.
Old 06-01-05, 11:28 AM   #2
fizzwheel
fizzwheel's Avatar
Sounds like you get a wet front spark plug.. its quite common
Old 06-01-05, 11:41 AM   #3
steveo
I've got a K3 and mine did the same. It's a nightmare especially as i had numb hands at the time, had only just started riding and had no idea what it was. Particularly interesting if the second cylinder comes back into play when negotiating a tight corner or something. Not fun. If it is the wet plug issue then a fender extenda fixed mine and has done for a fair few people on here by the sounds of it. They are only about 16 quid and fairly easy to fit.
Old 06-01-05, 11:52 AM   #4
Cloggsy
Front fender extenda solves a lot of the problems, but get the bike back to the dealers to sort out (if it's still under warrenty )
Old 06-01-05, 12:31 PM   #5
Grinch
Mines been splutering a bit now and again just lately and I have a fender extender. Though I have done a lot of wet miles, I'll have to have a look at the front plug this weekend. Though it might be the airfilter pulling to much water though... its servicing time....
Old 06-01-05, 01:04 PM   #6
fizzwheel
fizzwheel's Avatar
I've got K1 and so far I've never had a problem with this and yes it does get ridden in all weathers. I've got lowers so I dont know if they help keep the rain off the front pot
Old 06-01-05, 01:09 PM   #7
Grinch
Mines a K1 so it might be something else, though as it every now and again I'm inclinded to think its the front plug playing up. Probably the drain hole blocked up.
Old 06-01-05, 03:05 PM   #8
embee
embee's Avatar
Check the choke cables too, especially the back one (the easy one to get to) where it goes into the carb. They get corroded and the return springs can't seat the plungers properly.
Old 06-01-05, 11:25 PM   #9
+1 for the carb springs, on the carbed bike anyway- don't bother with the injected as you don't have any, so they won't be sticky
If it's a wer plug, I've found that just seriously splatching on the non-conductive grease did a world of good for mine.
Engine Breaking? Hopefully not. Engine braking - is that OK? butterick99 SV Talk, Tuning & Tweaking 14 12-09-09 10:31 PM
Weather... Baph Idle Banter 2 14-04-09 04:29 PM
Engine braking... any hazzards engine wise? John 675 SV Talk, Tuning & Tweaking 21 28-03-08 07:20 PM
Weather Dicky Ticker Idle Banter 24 18-11-07 08:53 PM
the weather? hovis 2007 Annual Rideout 61 28-06-07 08:48 AM
