Old 07-01-05, 02:15 PM   #1
Shinsei Jutsu
Default rear brake
I have found then the rear brake is sticking slightly. When I wheel my bike backward from where it is parked in the mornings it needs a bit extra as the back break seems to be slightly on.
Would this be that the rear caliper is seazing?
If so, what do I need to do to stop it?
Cheers all in advance.
Old 07-01-05, 02:25 PM   #2
Scoobs
Take the caliper off the bike, but do not disconnect the hose unless you are going to renew oil and bleed. Remove the pads and pump the pistons out slightly. Not too far now. Clean around the pistons with a cotton wool bud and some clean brake fluid. Push the pistons back in. Pump them out again and repeat until they feel freer. Clean the body of the caliper, where the pads normally go with a toothbruck or similar. If you are using oil (like WD40) or brake fluid to do this make sure you spray liberally with brake cleaner. You don't want this on the disks or pads. Pop you pads back in, fix back on the bike and pump the lever a few times.
If this don't sort it then you "may" need a new seal kit.
Old 07-01-05, 02:28 PM   #3
BillyC
BillyC's Avatar
Just don't do a Charnley and put grease on your discs!
Old 07-01-05, 02:42 PM   #4
BaggaZee
Mean!
Old 07-01-05, 03:36 PM   #5
jonboy
But oh so smooth braking.
zx600r rear 'break' question, (rear brake). steve.s Bikes - Talk & Issues 6 19-02-09 07:50 PM
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
Front Brake - Rear Brake? Stradders Bikes - Talk & Issues 35 17-09-08 04:44 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Brake light not working when rear brake is used.. StreetHawk SV Talk, Tuning & Tweaking 10 16-04-07 03:40 AM
