Old 25-01-05, 05:01 PM   #1
650newb
Default refilling the scottoiler
this is probably so easy to do but how do i refill my scottoiler? i have the refill bottle but how do i get the oil into the oiler
sry if this has been posted somewhere else!
Old 25-01-05, 05:03 PM   #2
Carsick
there's a tube with an air filter on which plugs into a rubber bit on the side of the reservoir. Pull that pipe off the rubber bit, leaving the rubber bit on the reservoir.
Then just plug the pipe from the bottle into that, turn the bottle upside and spill the oil everywhere.
Repeat until full or you run out of oil.
Old 25-01-05, 05:04 PM   #3
650newb
lol cheers, ill give that a try
Old 25-01-05, 05:38 PM   #4
Stig
Yeah don't try to fill it up "through" the air filter cause its bloody hard work
Old 25-01-05, 05:49 PM   #5
Some shops take the filler tube off the bottle and "forget" to give it to you when you buy it...
Old 25-01-05, 05:53 PM   #6
embee
embee's Avatar
FWIW the destructions say pull the black rubber bit out of the side of the reservoir and fill through the hole in the side, and don't overfill
Then says "make certain that the nose of the filler plug is correctly located when refitting".
Old 25-01-05, 06:01 PM   #7
650newb
well i done it, there was more in there than i realised, i only used a very small amount out of the bottle
Old 26-01-05, 08:28 AM   #8
No, not like that.
That's it, much better.
Old 26-01-05, 11:45 AM   #9
Carsick
That's probably why it takes so bloody long, then
Old 26-01-05, 11:52 AM   #10
Viney
You only have to go through the airfilter thing wehn purging the system (When it runs out of oil completely )
Scottoiler gavinsky23 Stuff Wanted 1 19-05-08 08:27 PM
Scottoiler Stevetmanchester Stuff Wanted 5 17-05-08 08:33 PM
Scottoiler gavinsky23 For Sale - SV's and SV related items 2 17-05-08 07:27 AM
scottoiler done. nothing to see here hovis South & West Surfers 26 25-01-07 12:18 PM
DIY Scottoiler Diveboy Bikes - Talk & Issues 1 11-03-06 08:51 PM
