Old 04-02-05, 10:34 PM   #1
ahlb0018
Default 2003 SV650N Front Indicators
All -
What would you guys recommend as an upgrade to replace the front stock signals on a 2003 SV650N? I bought a fender eliminator kit that included new signals for the rear, and it'll bug the hell out of me if I cannot replace the front ones. Does anyone know anyone who sells upgrade signals?
Cheers!
Old 04-02-05, 10:45 PM   #2
GC-SV
http://www.clearalternatives.com
http://www.banitmania.co.uk
I prefer the look of the clear lenses with chrome plated bulbs.
I think they may be on the links above.
Other than that, there is always the option of micro LED type fronts, also probably available on the above links.
Old 04-02-05, 10:49 PM   #3
ahlb0018
Default Neither
Neither of the two links have any signals for the SV650N - In fact, one of them is not even active anymore. Do you know of any other sites that offer turn signal options?
Old 05-02-05, 11:23 AM   #4
mattSV
mattSV's Avatar
Motrax do LED indicators - try a google on Motrax + LED indicators.
I fitted a pair to the front of my SV1000 about 6 weeks ago - see here for pics & info:-
http://forums.sv650.org/viewtopic.ph...ghlight=motrax
You will need the following:-
Indicators (£29.99)
Indicator spacers (About £6 I think from Motrax - these will cover up the gap that taking of the stock cators makes)
Resistors (About 50p each from Maplins - 10 watt, 10 Ohm) - these are needed to correct the flashing rate, without them the LEDs flash too fast. They are very easy to fit, even with my limited electronic skills
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 06-02-05, 01:12 AM   #5
Rich Curtis
Banditmania is active - just need to spell the link correctly
http://www.banditmania.co.uk/
front 2003 sv650 disc's dual-power sv Stuff Wanted 1 10-04-09 07:49 PM
2003 Pointy Front RH side brake disc. leegriffiths128 Stuff Wanted 6 13-11-08 01:14 PM
2003 SV650 front end pdeering For Sale - SV's and SV related items 3 04-10-07 01:51 PM
SV650N Front End in Good Condition, leftovers from GSXR Swap Ter For Sale - SV's and SV related items 3 07-05-06 02:03 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
