Old 26-02-05, 03:21 PM   #1
alexb
Default SCORPION BAFFLE.....
OK:
Road legal Scorp can with the baffle in.
No screw under the end to remove said baffle......
Welded in then yeh..?.............
Does anyone know where the weld is ?.....Can it be drilled out.??...
Or is it there to stay.??..........
Cheers.
Alex.....
PS: Anyone got a SV link pipe for sale?..
Old 27-02-05, 09:23 AM   #2
Scoobs
Is there a hole underneath the outlet that looks as though there should be a screw in there? If not it looks as though the baffle is in there to stay. Can you post some pictures of the outlet end of the can and I will be able to tell you straight away if it is removeable or not.
Old 27-02-05, 10:27 AM   #3
alexb
Default screw
There's no screw mate. I got a stainless Scorp on at the mo with the baffle out............
Theres deffo no screw on this one.......
Must be welded in then..
Old 28-02-05, 01:17 PM   #4
Swiss
Sounds like you have got a race can and not a road can. The Scorp does have a small screw to remove the baffle, I had one before I get flamed by any know it all upstart claming to be a guru on all things bike.
You can drop me a Pm if you want some help with it.
Old 28-02-05, 05:28 PM   #5
alexb
Default Can
From what the owner has said, (not got the can yet.) It has the e4 stamp on the end to make it road legal...??..........
I'll suss it out when it arrives..........If the baffle wont shift i'll get a nice long drill bit and drill a hole in the end of it from thew conector pipe end to make it nice and load......
Watch this space....!!...
Old 28-02-05, 06:30 PM   #6
The Polarbear
It sounds like you have a Road Legal type with E4 stamp that has a permanent baffle rather than a removable one!
Old 28-02-05, 07:22 PM   #7
alexb
Default can
Thought so......
Soon get round that little problem............
Old 28-02-05, 09:49 PM   #8
21QUEST
21QUEST's Avatar
Default Re: can
Originally Posted by alexb
Thought so......
If it's as described by polarbear then I'm afraid you have got more than a little problem to get round as sound reduction is done using silmilar construction to OE cans (chambers and tubes).
Not much louder than standard can as well. Bought a carbon fibre one ages ago , before removable baffles were available.
Ben
Nemo me impune lacessit.
Baffle - Scorpion Exhaust Ally SV Talk, Tuning & Tweaking 22 26-04-09 03:41 PM
Baffle to fit Scorpion end can jambo Stuff Wanted 3 19-08-08 08:04 PM
Scorpion baffle Bear Stuff Wanted 3 05-04-08 07:38 PM
Baffle for scorpion needed keithd Stuff Wanted 7 15-03-07 08:45 PM
Baffle for a round Scorpion End Can Grinch Stuff Wanted 4 30-10-06 01:15 PM
