Old 03-03-05, 09:08 AM   #1
Chris1
Default New carb jets required?????
I fitted a Scorpion race end can to my SV. A friend says I should get new carb jets. Is he right? If so, what do I need to get....and is it a difficult or expensive job to do??
Please help....if help is needed
Chris
Old 03-03-05, 09:25 AM   #2
BURNER
Some end cans don't need jets others do. I'd look for a shop that'll do a dyno run for you. Just a run usually costs me £10-£15- a chat with the bloke doing it should sort out whether you need some jets or not.
Changing the jets is easy.
Old 03-03-05, 01:18 PM   #3
Chris1
Default Thanks Burner
Your advice is good. I shall act on it pronto.
Chris
Old 03-03-05, 01:33 PM   #4
142.5 mains, it'll run fine, and save money on a Dyno Man telling you to fit 142.5s.
Old 03-03-05, 01:56 PM   #5
Mike1234
Isn't 142.5 a bit big for just an end can?
Old 03-03-05, 02:11 PM   #6
Not in my experience, even on a standard bike you can improve the mid-range with larger mains.
Old 03-03-05, 02:40 PM   #7
Mike1234
Couldn't agree more but the last time I put 142.5 in a bike was with a akrapovic full sytem and even then it was running a bit rich. Would have thought 140 would be spot on.
Where do you buy carb jets from? lloyd_christmas SV Talk, Tuning & Tweaking 17 04-04-09 08:32 PM
Main Jets SVDragRacer Stuff Wanted 0 01-03-09 08:55 PM
Standard Jets Cyclops Stuff Wanted 1 21-07-07 06:07 AM
New Jets??? Born again SV Talk, Tuning & Tweaking 4 11-05-07 12:53 PM
where to buy carb jets and shims Stormspiel SV Talk, Tuning & Tweaking 13 08-09-06 05:09 PM
