Old 03-03-05, 04:25 PM   #1
454697819
Default Batteries
Y is it, we pay 52£ for a new battery and less than a yr later its completly usless??
Just had mine checked as it wsnt holding its charge, they said as its a gel filled one it laying on its side wont be a problem (mine has to due to mods) but they have said its unservicable, they are not saying this to get money as they cant even supply the dam thing!
so any one know where i can get a cheap otimate and a new yusa gel filled sv battery
Not happy
Alex
Old 03-03-05, 04:32 PM   #2
Cloggsy
You should have spoken to 'baldood' - He's 'da-man' for batteries
Old 03-03-05, 04:34 PM   #3
Red ones
Red ones's Avatar
The battery is a bit crap - I'm on my third in 4 years - it now stays connected to an Optimate all the time (except when I ride but that is only because the lead is not long enough)
It has to be kept charged right up - the cold and any alarm will kill it in a matter of days
Old 03-03-05, 04:35 PM   #4
454697819
gonna have to get me an optimate, 50 quid every year for a new battery is takin the ****!
Old 03-03-05, 04:39 PM   #5
embee
embee's Avatar
it'd be worth checking the charging on the bike. One thing which dramatically shortens the life of lead-acid batteries is being only part charged all the time. The regulator/rectifiers on the SV are not of the finest!
Old 03-03-05, 08:40 PM   #6
The Yuasa isn't a gel battery, it is sealed though.
Getting through batteries at the rate you are, something else is wrong, most likely the reg/rec unit, they're not good.
Old 03-03-05, 08:55 PM   #7
454697819
hmmmm i was told is was gel, ho hum!
checked the reg rec, tis fine, i think its got more to do with the fact i dont ride the bike enough!
my own fault probably!
Old 03-03-05, 09:04 PM   #8
Reg/rec is fine says who?
Even a perfectly good standard one doesn't keep the battery charged up that well, it's better to fit a different one from a Kawasaki or a Honda instead, a small mod is needed to the wiring - Kawasaki and Honda ones have six wires instead of the original's five.
Batteries need a cycle of charge and discharge to keep them in good order, bikes in infrequent use could well do with the extra charge of a better reg/rec, better still an external charge regularly helps a whole lot.
Old 03-03-05, 10:07 PM   #9
mysteryjimbo
Default Re: Batteries
I got mine off Baldood. I also had a similar problem. My battery was useless after about 9 months so he replaced it under waranty, no questions asked!
He's the man!
Old 03-03-05, 10:10 PM   #10
454697819
He's the man!
Earth to baldood! if u read this, can you pm me about a battery, will try and pm you tommorrow! Cheers
Alex
Alarms and batteries thedonal SV Talk, Tuning & Tweaking 22 04-09-08 02:01 AM
swapping batteries redeye321 SV Talk, Tuning & Tweaking 2 29-11-06 08:24 PM
So...What kills batteries? Skeeter SV Talk, Tuning & Tweaking 2 11-10-06 09:24 AM
batteries for sv650s 2002 baggies666 Bikes - Talk & Issues 6 27-04-06 08:00 PM
batteries... benHallowes Bikes - Talk & Issues 6 05-04-05 08:55 PM
