Old 15-03-05, 10:21 AM   #1
stox
Default Hagon Shocks
Does anyone have a Hagon shock fitted to their SV? If so is it any good and are they easy too fit, looks like a good upgrade option. Im also considering the Hagon front springs with the preload adjusters from JHS, again can anyone comment?
Beware, I bought a GSX-R 750 shock from ebay that was sold as nearly new, it arrived knackered, I dont think I will risk fitting it!
Old 15-03-05, 10:30 AM   #2
Itching 2 go
Default Re: Hagon Shocks
not on an SV but i had one on my bros 400 it was utter #]@;><~ I'd never buy another
Old 15-03-05, 10:53 AM   #3
Iansv
I've generally heard good things about them, not got one tho
they did a sterling job of straighting my wheel tho if thats a recommendation
Old 15-03-05, 12:09 PM   #4
timwilky
timwilky's Avatar
Wigan650s has a Hagon shock with remote preload.
Not Grumpy, opinionated.
Old 15-03-05, 12:11 PM   #5
jonboy
But you can have it rebuilt for about £60 which will be close to perfect and a helluva lot cheaper than going for the Hagon.
Old 15-03-05, 12:14 PM   #6
Carsick
Or just try your luck on ebay again.
I got a decent condition gsxr1000 k2 shock for £10
Old 15-03-05, 03:17 PM   #7
legin
Default Hagon Shock
Stox - I recently fitted a Hagon shock to my wife's K4s and it has totally transformed the Bike. She weighs less than 60 kilos so the spring and damping internals were matched to her weight. This was an extra £40, but still much cheaper than a WP or Ohlins, which have a multitude of adjustments that you don't really need for normal road use.
The main difference is that on bumpy roads, the throttle can now be kept wide open, whereas before she would have to back off, as she was literally being fired out of the seat over every bump, which I must admit did look amusing when following from behind!
We've also had fitted Continental road attack tyres, which coupled with the Hagon, transform the Bike into the rapid lightweight sporting twin that Suzuki no doubt intended.
Fitting the shock was a straight forward dismantling exercise, as it is a like for like fit (no mucking about re-locating the battery tray, etc...) However I did have to file about 5 thou off of the shock mounting bush before it would fit snugly in the top mount. I used an ABBA stand which secures the Bike safely.
Incidently, when fitting the tyres and shock, I noticed that both wheel spindles and all the rear suspension linkages were bone dry, so I took the opportunity to grease them all before re-assembly. The Bike was new about 5 months ago, so it's obviously never been greased at the factory.
I can't comment on the pre-load mods, as the K4 comes with pre-load adjusters as standard. In fact the front forks work well with good damping charateristics, it's just the standard shochk that's so poor.
Hope this helps you decide.
Hagon & Nitron shocks neio79 SV Talk, Tuning & Tweaking 12 15-09-07 12:30 PM
Ohlins, Hagon, Hyperpro etc shocks for curvey Jase22 SV Talk, Tuning & Tweaking 19 11-05-07 11:32 AM
shocks socommk23 Bikes - Talk & Issues 6 20-01-07 04:09 PM
Shocks... BillyC SV Talk, Tuning & Tweaking 10 17-04-05 08:44 PM
Not shocks again !!!! chutz SV Talk, Tuning & Tweaking 15 05-03-05 08:59 AM
