Old 17-03-05, 08:01 PM   #1
Banus
Default Front fork Corrosion
Hi All,
I’m well impressed with the way the font forks come up after a bit of effort. I’ve always thought it the one part of the bike that lets the rest down..... so I’ve decided to have a go myself . Obviously its best to remove the front mud guard to get at the forks properly
Now for cleaning purposes Ive tried to remove this in the past but have noticed a really annoying little clip on the very top of the fender that supports a cable that goes down to the front wheel hub. Initially I thought it was a press stud type clip and tried to prise the two halves apart. Try as I might I cant seem to get it undone without using excessive force and risk breaking it or damaging the fender. Is this the only way to get it done and if so can a replacement clip be obtained ? OR do the two halves separate. Any advice would be great.
Finally - is wetndry, scotchbrite, T cut, and metal polish the best way to go ?
PS Ive heard of scotchbrite - but what is it
Old 17-03-05, 08:46 PM   #2
Viney
Yes, it is just a matter of prising the two bit apart. I use a car trim remover that i use when fitting car stereos etc.
Scotchbrite is like scouring pad. You can get it at most diy places. Get the fine finishing one, red in colour, not the green one, sod it, get the green one as well. Its a little more abrasive. If you are doing it with the forks in the bike, then put the axle back in. This will stop the fork lowers turning.
800 grit wet n dry was good as well.
Old 18-03-05, 11:45 AM   #3
Hooligan
Ive got carbon fibre sheeting over my front forks. It protects the forks during the winter and looks ace too. I put in on 6month ago and its still stuck strong and the forks are brand new underneath.
Just thought id share that with you.
Old 18-03-05, 01:59 PM   #4
Banus
Cheers,
Sound good to me, I might give that a go.Where did you get it from and is at made specifically for the SV ?
Old 18-03-05, 08:23 PM   #5
The Wolf
Kev,
I jsut painted my forks with 4 coats of smooth Hammerite (Silver). All the work is in the prepping. Started with 80 grit, then down to 240. Finish is excellent and should be hardwaring.
Can you repair front fork corrosion? robertjp SV Talk, Tuning & Tweaking 45 23-01-09 10:33 AM
Fork Corrosion duffbattye SV Talk, Tuning & Tweaking 8 19-07-06 04:30 PM
Corrosion On Front suspension bingopaul SV Talk, Tuning & Tweaking 5 01-02-06 05:09 PM
Fork corrosion Jelster SV Talk, Tuning & Tweaking 8 12-12-05 11:12 AM
fork corrosion kjames SV Talk, Tuning & Tweaking 7 09-11-05 12:01 AM
