Old 22-03-05, 10:39 PM   #1
stevelondon1979
Default Idle Speed
My bike has stalled once or twice soon after start when the clutch has been pulled in after moving a few metres, and I've a feeling it may be the idle speed too low in the cold weather. I know it's getting warmer, but I wanted to knock it up a few hundred revs. Is currently 1100 once settled. Can anyone plse tell me the right procedure for upping the setting, and what i should go to - was thinking around 1400?It's a K4 by the way.
Cheers guys,
Steve
Old 22-03-05, 10:40 PM   #2
Carsick
1100 is nice when the weather is good, but it's just not quite enough when it's colder. I have mine at 1400 and I don't have any problems, alot of other people seem to be about the saem.
Old 22-03-05, 10:57 PM   #3
BURNER
1300 rpm is what mine is set for.
Old 22-03-05, 11:07 PM   #4
Mr Toad
on the left hand side in the corner of the frame is a small philips screw in a white circle about the size of a 5p piece. turn it one way & the revs will go up , turn it the other way & they'll go down
see the manual for the precise location
cheers
Old 23-03-05, 02:19 PM   #5
jamieclayton9
when the engine is cold mine sits at about 900rpm. when it is warm it sits at about 1200. it seems ok at that. jamie
Old 23-03-05, 02:52 PM   #6
Ceri JC
Other way round, surely?
Old 23-03-05, 02:54 PM   #7
Carsick
It's a carbed model, so he can choose the choke level.
Wouldn't have thought it would idle happily at 900 when properly cold, though.
Old 23-03-05, 09:07 PM   #8
jamieclayton9
it sits at that just after i turn the choke off. doesnt take long to reach 1200. soz if i ave been a tad confusing. cheers all
Old 23-03-05, 09:10 PM   #9
RandyO
then you have your idle set at 1200, what it idles at cold doesn't count
Idle speed? weecorey SV Talk, Tuning & Tweaking 4 07-02-09 09:30 PM
Idle speed acting up Halfhidden Bikes - Talk & Issues 5 07-02-09 06:36 PM
Sticking Idle Speed mattglavin SV Talk, Tuning & Tweaking 20 31-07-08 06:45 PM
idle speed ? svdaz SV Talk, Tuning & Tweaking 11 29-04-08 05:32 PM
2001 SV Idle Speed Jamie_SV SV Talk, Tuning & Tweaking 12 23-02-08 06:02 PM
