Old 23-03-05, 03:35 PM   #1
bobit69
Default new exhaust problems
chaps, i have just bought myself a new viper exhaust and link pipe to fit to my SK3. i am having a few problems connecting the exhaust to the pipe. the chap at viper assures me that it is the correct pipe etc?
1. on the connector pipe is it the wider end of the 2 that connects to the silencer, ie goes over the top of it?
2. has anyone else had problems?
quick answers are appreciated as i intend to go blatting this evo!
cheers
Old 23-03-05, 03:43 PM   #2
PoRk ChOp
It should be fairly straight forward mate. Have you used a file on the rough edge where you cut the existing pipe? If not do that, then the link pipe should just slide straight over where you cut off the old exhaust, then the end can should just slip on the other end
Old 23-03-05, 03:52 PM   #3
bobit69
haven't cut anything yet... bit worried as i cannot connect the end can to the link pipe... can see how it all should connect buut all very tight!
Old 23-03-05, 03:56 PM   #4
PoRk ChOp
The link pipe has a thick and thin end The thinner end should just slide into the end of the new can I will be a snug fit but just wiggle it in, it will go in if you push hard enough (waiting for all the dirty remarks )
Old 23-03-05, 03:56 PM   #5
Anonymous
Well one end should definitely fit over the end of the can.
Idea : are you sure you are not using the link pipe that connects your old can back on should you need two. The diameter of that should be same both ends, whereas the new can to existing pipe one MAY be different.
Old 23-03-05, 04:11 PM   #6
bobit69
Cheers chaps... with the help or a LARGE pair of pliers, file and a rubber mallet all fits... just gonna set off with the angle grinder now... Wish me luck!!!!
Thanks,
Old 23-03-05, 04:15 PM   #7
Anonymous
I have this mental picture of a bent and mangled link pipe and can. Oh put something between pipe and swingarm if your using a grinder (or be careful!).
Old 23-03-05, 04:16 PM   #8
PoRk ChOp
Ditto
Old 23-03-05, 04:34 PM   #9
fizzwheel
fizzwheel's Avatar
I tried to do that when I fitted mine, took me 5 minutes and lots fo swearing to work out what I was doing wrong
Old 29-03-05, 04:14 PM   #10
bobit69
All on now..Looks and sounds awsome... Car alarms do not like it... (Neither do the neighbours when started up at six in the morning!)
Cheers,
L
Underseat exhaust problems - your thoughts? ocr_sv SV Talk, Tuning & Tweaking 25 14-05-08 03:23 PM
gasoline in my exhaust... fuel in my exhaust mtb83201 SV Talk, Tuning & Tweaking 5 29-04-08 10:58 PM
SV 650 Problems turlock SV Talk, Tuning & Tweaking 4 24-07-07 07:44 PM
micrin zeta exhaust system-problems- james160987 Exhausts 2 29-05-06 06:47 AM
