Old 02-04-05, 03:31 PM   #1
twnboarder
Default 2005 SV650S misfiring brand new!!!!!!!!!!!!!!!!!!!!!
Hey guys, just wanted to see if this has happened to anyone else. I picked up a 2005 SVS the other day, and after about 25 miles, it started to misfire horribly. Took it back to the shop, they said it was a connector but didnt say specifically what connector. would have to be a coil pack or spark plug, or battery issue IMO. Anyways, they said they got it started working again, so i rode it home but it was too cold to ride to work that day. Put my accesories on in the next few days, and then yesterday was very nice so i rode to work, all good. Rode home from work, all good. Got home, parked in the garage, got off the bike, and it started mis-firing again!!!! the RPM's go from 1,000 to 1500 and back down and back up constantly and you can feel in the exhaust its a misfire. Anyone else have problems like this, and did your dealer tell you teh problem, since my dealer seems to be ignorant on how to fix this bike. Thanks for any help!!!!!!!!
Old 02-04-05, 03:41 PM   #2
hall13uk
your dealer should be taking this problem more seriously get down there and tell them to get it sorted ASAP the ecu unit will tell them the problem once they plug it into there pc with the software installed. you have just spent best part of 6 grand on a bike dont be rude but be assurtive.
good luck fella oh & contact suzuki if need be there very helpful.
Old 02-04-05, 03:51 PM   #3
Carsick
If it's a connector issue in the HT part of the circuit, I doubt the ECU would even be aware of a problem.
I agree, though, get it down there again and make sure they tell you what the problem is.
Old 02-04-05, 05:04 PM   #4
twnboarder
Thanks for the replies guys. I took it back to the dealership just now and they are going to call Suzuki on monday. It just sux cuz its going to be the first nice weekend we've had here, and now I'm bikeless again.
Old 02-04-05, 06:30 PM   #5
TSM
The Sick Man
TSM's Avatar
I dont think they connect the ecu to the computer, they are not that complex. There is a service plug under the rear seat, with a rubber cover on it. You need to bridge the two pins and if there are any problems it will give an error code on the speedo.
Old 03-04-05, 02:07 AM   #6
hall13uk
they do i saw them do it. the errors come up on the pc screen.
Old 03-04-05, 09:22 AM   #7
Anonymous
Is it or have you made it wet? Doesnt sound completely like it but check the front plug connection tight and sealed well. If it hasnt been wet ignore this.
Old 04-04-05, 12:12 PM   #8
SV650Racer
They do connect it to a PC now using new software through Suzuki. Shows up all the fault codes.
Old 04-04-05, 12:42 PM   #9
TSM
The Sick Man
TSM's Avatar
finaly technology put to use.
Old 04-04-05, 01:51 PM   #10
454697819
maybee, but have u seen a suzuki mechanic with a computer
when it doesn start up they inevtably shove screw driver in it sum where and bugger it up,
(can u tell that i dont like most bie mechanics)
Brand New 07 Sv650s ohhh my Bikes - Talk & Issues 15 09-07-08 12:13 PM
SV650S K5 Misfiring? Elky SV Talk, Tuning & Tweaking 9 13-05-08 08:05 AM
2005 Sv650s Richk14 SV Talk, Tuning & Tweaking 10 24-01-08 10:36 AM
Brand new SV650S for under £4k! StreetHawk Bikes - Talk & Issues 10 25-03-07 06:55 PM
2005 SV650S BIGDOGS_SV SV Talk, Tuning & Tweaking 1 24-11-05 04:25 AM
