Old 03-04-05, 05:13 PM   #1
alka
Default Chain Cleaning
Would it be ok to use White Spirits?
Thanks
Old 03-04-05, 05:15 PM   #2
snoopy
Parrafin friend.
Old 03-04-05, 05:21 PM   #3
alka
would white spirits work
Old 03-04-05, 05:42 PM   #4
snoopy
nope.
Old 03-04-05, 05:53 PM   #5
jonboy
It might be a bit harsh, but then again it's one of the constituent parts of WD40, which to be honest might be a better bet as the thin oil would also help to remove stubborn tar like deposits.
Old 03-04-05, 07:11 PM   #6
rob13
Ive just tried cleaning mine today with Paraffin. I need to get a paddock stand to do it properly as i was on my own and had to keep moving the bike to get to the chain. done the top bottom and front but need to do the rear of it which ill do once i get a paddock stand.
I then used wurth high performance chain oil once it was cleaned.
Old 03-04-05, 07:25 PM   #7
jonboy
Learn to pivot the bike momentarily on it'd sidestand and then spin the wheel a few degrees with your free hand. This way the bike can stay where it is and you can rotate the wheel completely making for easy cleaning/maintenance.
Old 03-04-05, 08:13 PM   #8
curium
I just take the rear wheel out. Place a paint-roller tray with paraffin under the swinging-arm and rotate the chain on the front sprocket pulling it through the paraffin with 1 hand while using a clean paint brush to clean it with the other hand.
Once all the links have been through once, I dry the chain with a clean, dry cloth. Leave it for 5 mins for any residue to evaporate before oiling up with cheap, 80W gear oil.
Put the wheel back on and re-align the scottoiler.
This way I get to give the wheel-rim and sproket a good clean with the paraffin too.
Only draw-back is, after refitting the wheel, I have to clean the tyre surface with soapy water to ensure no oil is on the wheel.
Old 03-04-05, 08:18 PM   #9
alka
Does anyone know offhand how much chain slack is recomended.
Old 03-04-05, 08:23 PM   #10
BURNER
I use WD40 and some rags. Removing all the oil with parafin has never struck me as a good idea.
cleaning chain AndyBrad SV Talk, Tuning & Tweaking 21 31-12-08 01:58 PM
Cleaning the chain neilhatch SV Talk, Tuning & Tweaking 12 15-06-06 08:23 PM
Cleaning chain JASONSCOTLAND Bikes - Talk & Issues 16 27-03-06 12:43 PM
Chain cleaning diamond SV Talk, Tuning & Tweaking 29 30-05-05 11:49 PM
chain cleaning Warren SV Talk, Tuning & Tweaking 13 20-03-05 01:04 PM
