Old 15-04-05, 03:24 PM   #1
drumwrecker
Default Brake pedal
I need to either repair or buy a brake pedal as my local dealer wants £41 for one.
So a couple of questions
Can they be welded, i.e. argon arc?
Would another models pedal fit such as a Bandit, they look very similar but I'm not sure if the hole it pivots on is the same size?
Can anybody help.
Thanks
Old 15-04-05, 03:25 PM   #2
Carsick
The pivot seems pretty standard across suzukis (I know the gsxr ones are the same in that regard) but the way the springs and the master cylinder are connected is what can cause problems.
Old 15-04-05, 03:37 PM   #3
Couerdelion
Try www.patternparts.net
Old 15-04-05, 04:49 PM   #4
Biker Biggles
Biker Biggles's Avatar
I tapped mine and put a bolt through with a nut to lock it and support it. that was a temporary stopgap in January and still fine.In fact I prefere it now
Old 16-05-05, 04:03 PM   #5
drumwrecker
Thanks for the Patter Parts site.
In the end I got it welded. I had made the assumption that it was monkey metal that would just just glob up when welding. The guy who welded it said it had to meet certain levels of strength so was good quality alloy and welded well. Now I must try the broken brake lever.
K5 Brake pedal jamesobrady Stuff Wanted 1 20-03-09 08:02 PM
brake pedal help 01 sv650s SV Talk, Tuning & Tweaking 6 27-01-08 10:44 PM
Brake Pedal Fix! SV225 SV Talk, Tuning & Tweaking 4 03-08-07 12:02 PM
Rear Brake Pedal 01 sv650s Stuff Wanted 0 29-03-07 07:59 PM
Brake Pedal Steve226 SV Talk, Tuning & Tweaking 11 18-11-06 06:00 PM
