Old 15-04-05, 08:03 PM   #1
ilikebike
Default what is gained by slipping the clutch?????
I was riding a few minutes ago, and wanted to take off a little hard, so I let the clutch out a little slow(er than normal). After that it seemed like I was getting a lot more intantanious torque when I hit the throttle. Wanted to do power wheelies now, where it didnt before. So is there an explanation for this??? Does a clutch need to be slipped every once in a while to get it sticky again??? What is going on, is it really gripping more and transfering torque or am I imagining it???
Old 15-04-05, 08:06 PM   #2
Carsick
Sounds like you just managed to get the bike closer to the power band before you took off properly.
Old 15-04-05, 08:10 PM   #3
ilikebike
So why did it seem like it was grabbing a lot better on later accelerations and take-offs??? Does it grab better if it is warmer????
Old 15-04-05, 08:11 PM   #4
Carsick
I can't think of a good explanation, perhaps it just seemed faster after the rush of taking off.
Old 15-04-05, 08:25 PM   #5
wheelnut
slipping the clutch only serves one useful purpose, it makes your wallet lighter :P
Do you mean holding the clutch in and revving up then dropping it, to do a wheelie
Old 15-04-05, 08:27 PM   #6
philc2000
maybe you were using more revs than before, more torque, more power = faster acceleration.
You can burn a clutch out by slipping it lots... you have been warned.
Old 15-04-05, 08:32 PM   #7
Cloggsy
hall13uk, take note
Old 15-04-05, 08:33 PM   #8
ilikebike
I should have said this, but I never dump a clutch, and I only started letting it out at around 3000 and slipped it out to 5000. at 5000 it was all the way released. I guess all that I was thinking was that a warm clutch might be sticking better??? And as a second thought, maybe it needed adjusted?
REPEAT.... I never dump a clutch.
Old 15-04-05, 08:45 PM   #9
philc2000
having said that - clutches are fairly cheap
Old 16-04-05, 12:20 AM   #10
hall13uk
you know what i mean
Slipping Clutch ?? soldiermp SV Talk, Tuning & Tweaking 5 26-02-08 03:17 PM
sv650 k3 clutch slipping loneranger SV Talk, Tuning & Tweaking 2 04-11-07 04:47 PM
Slipping clutch, I think??? Kilted Ginger SV Talk, Tuning & Tweaking 4 16-09-06 05:55 AM
Clutch Slipping. Iceman SV Talk, Tuning & Tweaking 15 04-01-06 07:04 PM
Clutch slipping? Supadan SV Talk, Tuning & Tweaking 18 12-06-05 05:43 PM
