Old 07-05-05, 11:01 AM   #1
Anonymous
Default Hacksaws for exhausts
Hi
I'm going to install my new can today - obviously the link pipe needs hacking off - what type of hacksaws would you recommend, and how long does it take?
Also, for the stock exhaust mount bolt - does the toolkit come with the right spanner to take it off - as i need to do that (bike isn't here ATM so I can't check)
Martin
Old 07-05-05, 11:20 AM   #2
Carsick
A normal hacksaw works well, but can be a bit clumsy, so a junior hacksaw can be handy.
You just need to use a metal type blade.
Toolkit should have what you need.
Old 07-05-05, 11:32 AM   #3
Bomber
I found it took ages with a hacksaw! If you've got access to an angle grinder with a reasonably fine metal cutting disc it does a great job with much less blood, sweat and tears! And in about a tenth of the time
Old 07-05-05, 03:12 PM   #4
madEG
madEG's Avatar
Default Re: Hacksaws for exhausts
Before you start cutting the pipe off, tape some cardboard or similar to your swing arm, on the right side towards the front. When I was cutting off my exhaust, I would occasionally push the hack saw too far and make a small scratch on the swing arm, which lies behind the cut off point for most slip-on pipes.
You can barely seem them, but if I could do it again...
madEG is offline   Reply With Quote
Old 07-05-05, 05:39 PM   #5
sprocket
I used a dremel worked really well
Old 07-05-05, 09:32 PM   #6
GRINDER!!!!!!!!! piece of ****!!!
daz
Old 07-05-05, 11:07 PM   #7
fizzwheel
fizzwheel's Avatar
Watch out for your heel plates to
Old 08-05-05, 01:16 AM   #8
MitchC
Hey,
Remove the whole system and save your bike... It takes nothing to take the stock system off. 5 bolts and some manipulation on the headers. Also, hack saw worked fine for me. Buy a new blade and it took a minute or two. Went through easy and straight.
Mitch
Old 08-05-05, 10:18 AM   #9
Smiffy
A new blade on a full size hacksaw takes minutes in my experience [one pipe!]
Old 08-05-05, 10:36 AM   #10
weegaz22
i used a grinder
Huggers, K5 toolboxes and hacksaws Lozzo SV Talk, Tuning & Tweaking 0 19-01-08 06:41 PM
MTC Exhausts maultin SV Talk, Tuning & Tweaking 2 16-12-07 11:02 PM
Exhausts Duck-man SV Talk, Tuning & Tweaking 3 26-09-06 02:51 PM
Exhausts GSXR Carlos SV Talk, Tuning & Tweaking 4 01-06-05 11:09 AM
exhausts for k5 svs latts650s SV Talk, Tuning & Tweaking 2 24-05-05 08:11 AM
