Old 13-05-05, 01:51 AM   #1
Tex
Default Coolant leak LHS
Hello everyone,
My 2001 model SV650S seems to have developed a coolant leak on the LHS. It's a small amount coming from one of the engine casing bolts. I noticed that the all of these bolts have a metal washer, except the 2 most forward. I looked at another SV & sure enough it was the same story.
Of course the leak is coming from one of these washer-less bolts. Has anyone else here experienced the same thing? Is the fix as simple as whipping the bolt out & putting a washer in? Should I use a fibre or metal washer?
I've had the bike for years & this is a first.
Tex
PS. Just so we're clear, when I say LHS, I mean same side as the gear change
coolant top up steveg SV Talk, Tuning & Tweaking 10 19-01-09 04:19 PM
Oil in coolant ?! fatneck Bikes - Talk & Issues 16 26-02-08 09:14 PM
coolant leak SimJ SV Talk, Tuning & Tweaking 0 02-05-07 11:05 PM
Speedo Rotor & Engine coolant leak Nitzer SV Talk, Tuning & Tweaking 2 02-01-07 09:20 PM
Not oil leak - Petrol leak - double "Bugger"...! Potts SV Talk, Tuning & Tweaking 1 17-10-04 08:16 PM
