Old 17-05-05, 09:52 PM   #1
BILLY
Default REAR TYRE
WHAT REAR TYRE SIZE CAN I GO UP TOO? I WOULD LIKE TO GO UP TO 180 , WHITCH RIM WILL FIT AND HOW?
Old 17-05-05, 10:21 PM   #2
jonboy
Don't waste your time, seriously. The SV's wheel won't reliably accept a 180 section tyre as has been proven (tragically) in the last year as someone was killed as the tyre came off the wheel.
It will also slow your steering and has no benefit apart from looking a bit fatter.
Old 17-05-05, 10:39 PM   #3
Cloggsy
Sorry for the derail, welcome to the site Bill...
Where abouts in Hull are you... I'm from Hull (originally) too...
Old 22-05-05, 07:07 PM   #4
BILLY
Im from east hull sutton trust. ive heard that the GSXR 750 rim will fitt but need to know how?Also the front end.
Old 23-05-05, 09:32 AM   #5
coombest
All of this does beg the question of "Why!?"
As Jonboy has already said, the only practical purpose a larger rear will serve is to slow down your steering significantly. Add to that the fact that it has been proven to be not entirely the safest plan of action!
I have a Triumph T595 Daytona which has a 190 section rear fitted. I have found out after fitting another 190 to replace the one that was fitted when I bought the bike, that Triumph (and the tyre manufacturers) recommend both a 190 and a 180 section tyre for fitment. Looking on the web and talking to other owners, many people prefer the 180 as it improves turning ability and speeds the handling up "no end!" If I'd have known this before I went for new tyres, I would have gone for the 180!
(So basically, a bigger tyre is not necessarily the best thing!)
As for the front end, there are many people who have changed the front ends of their SVs because the OEM suspension is not as good as it could/should be. The popular choiced are GSXR1000/750/600 & the YZF-R1. However, these are not simple pull-out, slot-in jobs. They do take a lot of engineering to get them fitted properly. If you run a quick search you should find some relevant info.
rear tyre plowsie Stuff Wanted 4 15-03-09 10:15 PM
Rear tyre available RGV250ads SV Talk, Tuning & Tweaking 0 15-08-08 01:58 PM
180 rear tyre on a 650 ?? SV-net SV Talk, Tuning & Tweaking 13 19-01-08 07:25 PM
170 rear tyre on SV CHICKENSTRIPS SV Talk, Tuning & Tweaking 9 24-07-07 01:27 AM
How much is a rear tyre for you? JakeRS SV Talk, Tuning & Tweaking 5 06-06-06 02:43 PM
