Old 22-05-05, 03:39 PM   #1
moodyman
Default Horn Upgrade
Just trying to upgrade my horn to one of the curley air horn types.
The one i'm installing only has 1 spade type connector opposed to the 2 on the original, therefore I'm using a circular connector around the thread where it's held on.
Hor works fine until I fasten it to the bike, then it sounds constantly????
Any ideas??, it's doing my head in
Cheers alll......
Old 22-05-05, 03:59 PM   #2
Anonymous
Is it shorting out?
Old 22-05-05, 04:05 PM   #3
moodyman
As soon as the thread touches the mounting bracket (or any other part of the bike) it causes the horn to sound constantly. When not touching the bike works fine???
Any ideas
THANKS
Old 22-05-05, 04:06 PM   #4
derbybiker
From what I can remember when replacing my horn the SV's horn is 'earth activated' and you have to connect the relay up slightly different - this could be your problem.
If you already know this then I'm sorry but I can't help, if you didn't know this and require a diagram let me know and I'll try and dig my instructions out.
Old 22-05-05, 04:08 PM   #5
moodyman
Any instructions/Advice appreciated, I aint got a clue on this matter
Old 22-05-05, 05:22 PM   #6
Well Oiled
Derbybiker's right - there's 12V to the horn all the time the ignition's on and the horn switch completes the circuit on the earth side. To me you've two options:
1) Mount the horn on a piece of strong plastic to isolate the horn from the chassis, then put your wire from the horn mounting screw to the other spade connector on the SV's wiring (sounds like you're already doing that). That way the circuit is only complete via the horn button as before.
2) If they'll have the horn back, swap it for one with a positive and negative teminal, which works the same as the standard horn.
Cheers and good luck Keith
New Horn maultin SV Talk, Tuning & Tweaking 24 11-07-08 03:16 PM
I want to get the horn maultin SV Talk, Tuning & Tweaking 11 25-06-08 11:57 PM
Use of horn Blue_SV650S Bikes - Talk & Issues 31 13-12-07 10:35 PM
Got the Horn? metalmonkey Idle Banter 0 24-10-07 04:57 PM
Horn Elio SV Talk, Tuning & Tweaking 23 14-05-07 04:26 PM
