Old 29-05-05, 10:53 AM   #1
bobit69
Default Replacement Steering Stem Head
I am in the process of changing the steering stem head as some little gits decided to snap the steering lock, which in turn snapped that.
A slight problem is that I have come accross a couple of bolts which I cannot undo. They look like you should use a torx fitting but have a pin through the middle of the bolt. Does anyone know/come accross these types of bolts before?
Any help greatly appreciated!
Thanks,
Old 29-05-05, 11:09 AM   #2
Cloggsy
Yup, they're the security TORX bits, you can buy special bits to undo them from a tool speciallist - I bought a full set (in anodised gold ) for about £12.99, alternatively, use a small screwdriver & a hammer to smash the pins out
Old 29-05-05, 11:43 AM   #3
bobit69
Cheers,
I managed to get the set... Hey presto, all fixed.
Thanks.
Old 29-05-05, 11:47 AM   #4
Cloggsy
Originally Posted by bobit69
Cheers,
Thanks.
That was quick
Steering stem cammy SV Talk, Tuning & Tweaking 3 30-04-09 06:26 PM
Steering stem removal Torn-Thorax SV Talk, Tuning & Tweaking 17 20-09-07 10:12 AM
Steering Stem Assembly Question Torn-Thorax SV Talk, Tuning & Tweaking 1 21-04-07 08:05 AM
Steering Head Stem Nut scooby2102 SV Talk, Tuning & Tweaking 0 06-12-06 01:41 PM
How to tighten / loosen round nuts on steering stem?? Khewett SV Talk, Tuning & Tweaking 4 14-05-06 09:33 AM
