Old 30-05-05, 06:10 PM   #1
lurcher
Default stripped thread
hi,while putting hel lines on i stripped a thread on the caliper ,is there any repair i can do,the 1st 2 lines went on o.k.then this happened
Old 30-05-05, 06:49 PM   #2
daddy_sperm
you could try drilling it out and fitting a heli coil.
Old 30-05-05, 07:06 PM   #3
Richie
fantabulas
Richie's Avatar
I would consider you get professional help....
After all Your brakes are the most important part of you Bike...
ps. heli coil might work but brake fluid is strange stuff and likes to leak through certain types of metal after a period of time, Me I wouldn't do it . I would be tempted to buy a new caliper..
My Flickr photos
Old 30-05-05, 07:23 PM   #4
daddy_sperm
true Ritchie, never thought of that
Old 30-05-05, 08:07 PM   #5
lurcher
Default stripped threads
hi,cheers for the advice i"d thought about heli coils but needed to see a mate for more advice,with it being the brakes i"m lookin for a new caliper
Old 30-05-05, 08:25 PM   #6
TSM
The Sick Man
TSM's Avatar
the thread on the calipers dont stop the fluid comming out thats the pressure on the banjo and the copper washers against the caliper. Get a heli coil, rethread the caliper and sort it out, should not be a problem at all. Make sure you put the copper washers on though.
Old 30-05-05, 08:45 PM   #7
M.C.
M.C.'s Avatar
you could always drill it out and tap it the next size up.
M.C. is offline   Reply With Quote
Old 30-05-05, 08:51 PM   #8
TSM
The Sick Man
TSM's Avatar
no, i was told you only get banjo bolts in one size for metric & imperial.
Old 31-05-05, 09:44 AM   #9
DeeJay
i would recommend you buy a new caliper.... you don't want to mess around with brakes!!!!!!
Old 31-05-05, 10:08 AM   #10
timwilky
timwilky's Avatar
Replace the caliper, I would not trust a helicoil for something as important as my brakes. Remember if it fails you will loose both your front brakes as there is no independant feed to each caliper.
There are usually some floating about on ebay, but get new seals just to be sure if you go this route.
How the heck did you manage to strip it? overtighten or cross thread
Not Grumpy, opinionated.
stripped heads Wideboy Bikes - Talk & Issues 10 08-07-08 09:15 PM
Help - Stripped Thread!!! Alpinestarhero SV Talk, Tuning & Tweaking 22 17-11-07 11:58 PM
Stripped thread issue, please help james160987 Bikes - Talk & Issues 4 19-07-06 07:51 PM
question reguarding lower fairings, and stripped thread james160987 Bikes - Talk & Issues 1 18-07-06 05:28 PM
Sump plug and stripped casing thread. mysteryjimbo SV Talk, Tuning & Tweaking 11 12-06-05 12:17 PM
